Author Topic: Schematic for this pwm controller anyone?  (Read 4808 times)
Offline WimberleytechTopic starter
« on: February 18, 2018, 02:59:42 pm »
Before, I reverse this, maybe somebody already has a schematic of this controller they would share.
Thanks!
https://www.ebay.com/itm/12V-40V-10A-PWM-DC-Motor-Speed-Controller-with-Knob-D7Y1-/172622352700
Offline amspire
Re: Schematic for this pwm controller anyone?
« Reply #1 on: February 18, 2018, 03:21:38 pm »
I don't have the circuit, but it looks like a NE555 (SA555) based circuit with the potentiometer controlling the pulse width of the 555 oscillator. The SA555 is just a lower temperature version of the NE555.
The 555 can only run up to 18V, so there is probably a zener on the board to limit the 555 supply voltage.
It is a PWM controller for a DC motor. Doesn't set a regulated speed, it just lets you make the motor go faster or slower.
« Reply #2 on: February 18, 2018, 04:45:50 pm »
Thanks.  I got that much, but there is a jumper on board.  Curious about what is there for.  I will reverse the thing of nobody produces a schematic.
« Reply #3 on: February 18, 2018, 07:46:24 pm »
Thanks!
I have traced it out and drawn it in a haphazard schematic, and then did a search for a similar circuit using search term: 555 pwm motor speed control
Happily, I found this schematic which is essentially the core of what I extracted.  The only difference is that I found a protection diode in series with the power supply connection and a constant current diode feeding a zener diode, providing the positive supply.
But as far as the pwm circuit, I extracted the identical implementation as shown in this schematic.
« Reply #4 on: February 18, 2018, 07:56:58 pm »
Jumper is a power switch to disconnect the controller and produce no output, using a low current switch so as not to have to switch the full motor current.
The following users thanked this post: Wimberleytech
« Reply #5 on: February 18, 2018, 08:32:16 pm »
Indeed.
Online Zero999
  • 0999
« Reply #6 on: February 19, 2018, 09:34:13 am »
Thanks!
Why not use a MOSFET for Q1? It will have a much lower power loss, than a Darlington pair.
The TIP122 is also only rated to 5A continuous, so no good for 10A.
47R is probably too low for the base resistor. The maximum base current of the TIP122 isn't specified on the data sheet, but it's certainly less than the >200mA that would flow, when there's a 12V power supply. The NE555's maximum output current rating is also only 200mA, so you're pushing it to the max.
https://www.onsemi.com/pub/Collateral/TIP120-D.PDF
« Last Edit: February 19, 2018, 09:35:50 am by Hero999 »
« Reply #7 on: February 19, 2018, 01:30:40 pm »
Thanks!
No argument here...MOSFET is optimal.  But, I am not designing this...I am merely extracting the circuit.  I bought one off ebay and wanted to have a schematic.  After extracting the 555 portion, I did a google search and found the schematic that I posted with the darlington.  I did say that the circuitry was "identical" but, actually, I cannot see the markings on the driver because it is packed between two heat sinks...so I do not know if it is MOS or BJT--so I was incorrect to say "identical."
Online Zero999
  • 0999
« Reply #8 on: February 19, 2018, 07:11:32 pm »
Thanks!
If you've already got the circuit, then how about replacing the TIP122 with a suitable MOSFET, such as IRFB3806, IRFZ44Z, IRLB8748, IRLB8721, TK30E06N1, NTD4815N-35G? No other modifications are necessary.
« Reply #9 on: February 19, 2018, 07:48:03 pm »
Impossible to remove without destroying the board.  Thanks for the tip though (pardon the pun).
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: February 19, 2018, 09:03:50 pm »
Related thread I put some comments on:
https://www.eevblog.com/forum/beginners/ne555-spikes-on-output-why/msg1429612/#msg1429612
Actually, the schematic above may well be relevant to that thread...
Seven Transistor Labs, LLC
Online Zero999
  • 0999
« Reply #11 on: February 19, 2018, 09:41:45 pm »
How is the TIP122 the soldered to the board?
Why would removing it destroy the board?
« Reply #12 on: February 19, 2018, 09:58:04 pm »
Well, it is mounted on a heat sink which is soldered to the board.  Plus, the three legs soldered to the board.  I could desolder the transistor easily enough but...it is called a heat sink for a reason...
Yes, I could get it off without destroying the board if I had the desire and the patience.
At any rate, since I have kicked up so much dust with this simple question, and knowing that everyone is on pins and needles wrt the transistor, I powered it up and took a look at it with a scope--it is a MOSFET.
