Author Topic: schematic needed  (Read 1994 times)
Offline p.larnerTopic starter
schematic needed
« on: October 23, 2023, 01:04:29 pm »
i want to build an oscillator to drive a small transformer that will output ac,the output of the transformer only needs to be a few ma at say 24v max,powered from an 18650,any ideas?.its to build a small octopuss component tester to work with a handheld scope in xy mode,the idea is basicaly have a small portable huntron tracker.
Offline Terry Bites
Re: schematic needed
« Reply #1 on: October 23, 2023, 07:50:50 pm »
4000 series cmos will work happily down to 3V.
Paralleling gates gives plenty of output drive for your mosfets or transistors.
Offline Roehrenonkel
« Reply #2 on: October 23, 2023, 08:00:32 pm »
Hi Terry,
sorry to contradict you, but a square-wave will not do for a component-tester.
Sine- or triangle-wave is needed (imho).
Best regards
Anyone still using VXI-Bus?
« Reply #3 on: October 23, 2023, 09:40:46 pm »
thats what i thought,a square wave will smack a transistor or diode junction on or off,not turn it on in a linear manor to display properly on a iv tester?,is that right?.
Offline Kim Christensen
« Reply #4 on: October 23, 2023, 10:13:09 pm »
I assume the amplitude and frequency isn't super critical:
You could LPF a 50/60Hz square-wave or triangle-wave (to turn it into a pseudo sinewave) and feed that into an audio amplifier IC to drive a small step up transformer. (Low voltage mains transformer in reverse)
Or feed the AF amp from a phase shift oscillator running at 50/60Hz.
« Last Edit: October 23, 2023, 10:19:13 pm by Kim Christensen »
