Claude AI thinks ...
ChatGPT thinks ...
No, of course it doesn't "think". Is this some kind of late April's fool joke, in which everybody pretend to expect precise engineering answers from a LLM, only to entertain themselves when they see me arguing how such expectation can not be fulfilled?
This is what a LLM will produce, as far as I know, and this is why the answers are incorrect most of the time:
Google AI says "Observing a 10 microvolt (µV) peak-to-peak (Vpp) signal is extremely difficult on a standard Tektronix TDS series oscilloscope because the signal is likely below or at the instrument's inherent noise floor and minimum vertical sensitivity"
The attached screenshot ts_ch4_1MHz_10uVpp__Ch2_100kHz_10mVpp.png shows that in reality it is not so difficult.
That shouldn't be a surprise.
The so called "Artificial Intelligence" name is misleading. AI is not "intelligent", and it does not return knowledge. A LLM generates "words salad" responses, but with a given theme. (LLM=Large Language Model, like ChatGPT, Grok, etc.)
Not kidding, this is how a LLM works. A LLM starts from your "words", and returns other neighboring "words" that happened to be in the vicinity of your question. Well, not exactly words, so let's call them "tokens". The "distance" between the input tokens (what your requested) and the generated tokens (the constructed answer) is spiked with random noise, to avoid an identical answers, so it won't repeat itself if you reformulate or refine your request. This is how LLMs normally work, this is not about "AI hallucinations".
AI generated content only "looks like" it makes sens, but in fact the content is meaningless. AI behaves like the perfect "impostor": It replies with the vocabulary and the confidence of an expert, but the answer is not expert knowledge, the answer is "words salad", or "tokens salad". Sometimes the words salad happens to be correct, but this is just a matter of luck. It is not a proper answer, it's an illusion.
A LLM answer is nothing but a fairy tale story. A fairy tale composed on the spot, for you only, about the theme you were asking. The term for this kind of AI generated fairy-tales-with-a-theme is "AI slop".
All the AI answers, even the "good" ones, are in fact AI slop.
(sorry for quoting myself, but I've just wrote that a few hours ago, won't copy-paste, and only quote instead)
Does everybody really expect correct engineering answers, or do you guys were just asking AI for entertaining purposes. I'm not mocking anybody, but I've wrote about the same warning message as in the quoted text, wrote that more than a few times so far, in different forms and with different words, and no reaction.
Apparently people don't believe me. Is it that everybody who is using AI, somehow becomes "hypnotized" by AI slop? Or is it something that I don't know, or did I get it all wrong about what a LLM does? What makes everybody keep asking AI, then struggling to make sense of a words-salad answer, then double checking if it really is correct and applicable or not, when it is obvious that many of the AI answers are as correct as tossing a coin.
(Legit questions, not trying to be rude. I dared to ask you all these only because you are the one who made me pay attention to AI many years ago, long before ChatGPT, when you told us about an AGI prize, and if AGI would be possible at all, remember? It was in a group chat from hackaday).
