An old but very reliable detector is simply a light source, in this case incandescent lamp severely underrun at around 60% of rated voltage, or an IR LED or red LED run at around 30mA of current, and a solar cell that is driving a resistor load, and then capacitively coupling the resultant voltage change into an amplifier and then using that to detect the seed passing. Simple, rugged and reliable, and works on only the seed falling through the beam and attenuating the beam slightly, not actually obscuring fully. Solar cell is simply a wide section of cell, which develops around 300mV when illuminated, and placed behind a glass protective window as wide as the desired detector area. As you only are using a single cell section , a slightly larger cell with the mask obscuring the edges has little effect, just using a monocrystalline cell sliced to size.
