Hey all,
I am working on designing a power meter. I know you may say there are hundreds out there however, I would like mine to be a little different (from any I have seen anyway). I am planning on having a base unit (Beaglebone or similar) inside with remote current measurement in the main switchboard or somewhere else. These current measurement devices would be interrogated at a certain interval and logged online directly.
My main question is, is there a way to successfully power the current measurement unit (CT or hall effect) using induction? would I be able to power the device using the output of the CT? Even if I have a small lithium battery built in that charges itself when the unit is not being interrogated for data to smooth and regulate the supply.
I am guessing its not, but I just wanted to put it out there and see what you thoughts where.
Also, side note.
Is there such a thing as a compact 3 phase plug in Australia? about the size of a standard power point?
Lee
