Hi all,
I’m interested in tracking temperature and humidity in several areas in my car, and am researching sensor and bus alternatives for the sensor network. I’d like to make each sensor node as simple, small and cheap as possible, and I’m looking at harness lengths of 5m-10m or so max.
For this application, LIN bus seems perfect - no wonder, this is exactly what it was developed for. However while there’s a plethora of easy to use temperature and humidity sensors with digital outputs over I2C or 1-Wire, it seems very difficult to find similar products with LIN output.
Of course I could use an analog or I2C sensor, an ATtiny and a LIN transceiver, but that is a lot more complexity in the sensor nodes than I wanted. I’m not so confident in using I2C directly over this length in an automotive environment over 10m. 1-Wire could be an option, but I don’t have experience with that. Is that robust enough for an automotive environment?
Do simple temperature and humidity sensors with LIN bus interface not exist? I have the feeling I’m missing something obvious.
I’d be curious if anyone here knows of temperature and humidity sensors with integrated LIN bus output, and where I could find them.
