Hey everyone,
I am banging my head over that thing... I have been looking through my junkpile and found two of those rather nice (considering that it can be controlled by only four pins (+ supply)) VFD with integrated controller. Now, I looked at the datasheet, which can be found
here, I am a bit confused.
First, whoever made the datasheet seems to have forgotten the nomenclature used in the pin description, as VDD and VEE are in the pinout diagram all of the sudden called VDD1 and VDISP.
Also, if you look at the suggested wiring scheme on page 3, there are a Zener diode and R3. No values! why? Am I missing something obvious?
I mean, it is obvious that those are used to bias the heater of the VFD to a known level in regards to the grids, but which bias does that thing need? I can't find anything in the datasheet...
Also, when I connect it the way it is shown (without the biasing or with F- connected to GND doesn't matter), the VEE/VDISP section seems to behave like a short circuit, which results in R4 letting the magic smoke out. As there is no wattage given for R4 (and no usual current consumption of VEE) I can't figure out if it is just damaged or if I did anything wrong, or maybe if I just need a bigger R4...
What the hell am I missing here?
Thanks in advice.
