Hello,
I am reading this spec
ftp://ftp.seagate.com/sff/INF-8074.PDFwhich I got through wikipedia.
How do I interpret this
"VccR and VccT are the receiver and transmitter power supplies. They are defined as 3.3V ±5% at the SFP connector pin. Maximum supply current is 300 mA."
but
"VccR and VccT may be internally connected within the SFP transceiver module."
So is it 300mA per pin, or 300mA all together? For my board it would be the difference between adding a linear regulator at the cage, or needing a dedicated switcher for the SFPs, especially if I add more SFPs...
I also worry about the rather slack nature of the spec, in that I'm sure the day the PCB gets built someone will find a SFP that needs 400mA per pin...
TIA!
