Author Topic: Siglent SDS2104X Plus - Scope-internal frequency visible in FFT?  (Read 1926 times)
Offline RandomUserTopic starter
« on: December 20, 2023, 03:35:46 pm »
Hello,
I want to do some pre-compliance EMC measurements with my SDS2104X Plus. Unfortunately, it shows 2 peaks when directly terminated into a RF-50R SMA.
I'm using channel 3 as input for the FFT.
Is this my scope?
Does anyone else has such a problem with his siglent?
Do I see an internal SMPS regulator showing in my spectrum?
See attached picture.1958295-0
Any feedback is appreciated.
Thanks!
Re: Siglent SDS2104X Plus - Scope-internal frequency visible in FFT?
« Reply #1 on: December 20, 2023, 08:34:44 pm »
Okay, did some research...
A big thanks to Dave for the HiRes photos.
I post a snippet of that below.
1958583-0
The power supply IC is a TI TPS65400 4ch buck.
The datasheet specifies a minimum SW-Freq. of 275kHz set by an external resistor.
When doing the FFT on ch. 1-4 I get to see 281kHz with RBW~1kHz. So basically min. frequency. Might be slightly off e.g. due to resistor tolerances.
Due to the distance of the supply to the analog input / ADC circuitry I suspect the ripple on the supply voltage to be the verdict of my FFT result.
On the other hand I get the best result on Ch3 which has the same supply as Ch4, I guess? Therefore, I would expect to see same results on those channels but when doing the same settings, this is what I get.
1958589-1
Any ideas?
Offline temperance
« Reply #2 on: December 20, 2023, 08:45:45 pm »
Volts = 10(dBV/20
-110 dBV= 3.16 µV
Good luck.
« Last Edit: December 20, 2023, 08:50:03 pm by temperance »
Offline 2N3055
  • Country: hr
« Reply #3 on: December 20, 2023, 09:36:29 pm »
That noise floor is actually crazy good....
Dr. Richard W. Hamming
Offline lucy.sierra
    • Sierra Circuits
« Reply #4 on: January 05, 2024, 05:11:08 pm »
Ken Wyatt could help you out.
