Author Topic: Signal Delay Circuit  (Read 5496 times)
Offline RadardudeTopic starter
« on: January 17, 2014, 02:03:05 pm »
I have a tankless water heater and a water solar system. I'm designing a circuit to delay the tankless heater from turning on allowing the hot water to reach the tankless heater. A signal from the internal flow sensor activates the tankless heater. IC1 is a retriggerable monostable multivibrator. The IC1 output pulse is longer the than slowest signal freg. R2 and C2 will provide the delay of the signal through IC2. My question, is there a simpler way to do this or a better way?
Online tszaboo
Re: Signal Delay Circuit
« Reply #1 on: January 17, 2014, 06:23:39 pm »
If you are going to fool yourself that putting an RC on a digital signal is a good solution, at least put a schmitt trigger input part after it.
Offline dannyf
« Reply #2 on: January 17, 2014, 06:31:21 pm »
1. 555 timer, or
2. mcu.
« Reply #3 on: January 17, 2014, 09:52:15 pm »
Pin 1 of IC2 is like a switch, it will slowly charge up (about 60 secs) until it is seen as a high allowing the signal on pin 2 to pass out of pin 4. Pin 1 will remain high as long as the water is flowing. So I don't think I need a schmitt trigger. Timing of the signal is not important. I'm trying to keep the component count as low as possibly.
Offline electronics man
« Reply #4 on: January 17, 2014, 10:27:18 pm »
I think an mcu is the best idea as you can easily experiment whith different times. You could use a 555 time but it is more difficult to experiment whith diferent times mcu is just the easiest. All you need is a cheep small mcu like picaxe 08 if you don't have another one in your BOM or you could use any mcu you want.
follow me on twitter @get_your_byte
« Reply #5 on: January 19, 2014, 06:17:43 am »
At first when you suggested to use a MCU I thought that was such an overkill. I have used Basic Stamps and Basicx BX24p on several elaborate projects in the past. But I didn't realize that such small and inexpensive MCU existed. I will use this MCU because of the small packaging and the small learning curve involved. It will provide a smaller component count than my design. This information opens up another wave of projects for me. Thanks for sharing.
Offline Skimask
« Reply #6 on: January 19, 2014, 06:32:06 am »
PIC10F200
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline calexanian
    • Alex-Tronix
« Reply #7 on: January 19, 2014, 07:39:18 am »
How about just a standard time delay relay. Nice, cheap, ready to go, and reliable. Amazon has many upon manys of them.
Charles Alexanian
Alex-Tronix Control Systems
« Reply #8 on: January 19, 2014, 09:02:26 am »
I don't have the space for a time delay relay. It would still require additional components because the flow sensor signal (1hz to 100hz 0 to 5V) which is the activating signal.
