Hello! I have been running tests using various sigrok compatible logic analyzers for about two weeks. I am running both PulseView and sigrok-cli on a rasberry pi 5. PulseView has been running great and I can collect 5G samples @ 24MHz (the max for most of my logic analyzers). However if I try to collect with sigrok-cli (with the same settings) I often get the error "device only xxxxxx sent samples", ans sigrok-cli dumps back out to the command prompt.
Should I be collecting samples using binary file output in sigrok-cli? I was hoping performance of sigrok-cli would be much better or at least the same as PulseView.
