Hi All,
I've been brewing on a simple DDS amp/buffer for those cheap ebay AD9850 modules. I'm only focusing on a sine wave at the moment, as that's what I'll mostly use in my audio stuff. (I can later add something with a 74hc14 and the same style amp/buffer).
I just made up something quick with an NE5539 (wide bandwidth, high slew rate op amp) and a BUF634 buffer to drive loads that demand it. 50Ohm output impedance; 10Hz <-> 10Mhz.
Anywho, it works pretty good (on breadboard, not ideal at high bandwidths for the NE5539) - so I'm looking to transfer this over to a small PCB. Planning to go SMD; but that NE5539 is _old_.
So, anyone have a suggestion for a replacement? Looking for something that has an equal (or better) bandwidth range; but comes in SMD; better or equal slew rate (keeping those square waves in mind in the future..); same for the gain bandwidth.
If I make a PCB, I'll open-source it. It would be nice if you can get samples of the parts in question. That way other people can build it pretty cheap as well..
I've attached a schematic and some scope shots. Output is -pretty- linear. Hey; it doesn't have an AGC, but it's cheap and good enough
