is there any free
simple to learn/use (one off use so don't want to spend time learning "complex" software) timing diagram software?
Nothing fancy, I just need to draw various waveforms showing delays (i.e. with the classic vertical alignment lines) and few labels here and there to label what happens at certain points in time.
I have come across some which require you to input the waveforms via text/program. I am actually looking for something I can just "draw" the waveforms.
If not a software specifically designed for this, then what software do you use?
(obviously I could use most graphic design software to design the signals lines but I am looking for something more "dedicated" to avoid wasting time redrawing a lot of it if I need to shift waveforms around (in time or vertically to reorder them)
Thank you
