Author Topic: Simple LED pulser  (Read 705 times)
Offline mawyattTopic starter
Simple LED pulser
« on: September 26, 2025, 01:17:12 pm »
While posting on EDN Design Ideas a reader reply mentioned using this inverted transistor to pulse a LED. Adding a LED in the inverted 2N3904 Collector to Ground produces a simple LED pulser.
Check here for the circuit concept
https://www.eevblog.com/forum/testgear/fooln-around-with-dso-awg/msg5939296/#msg5939296
And here for EDN article, note reader comments:
https://www.edn.com/unusual-2n3904-transistor-circuit/
Best
« Last Edit: September 26, 2025, 01:21:14 pm by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: pardo-bsso, MK14
Offline Dan N
Re: Simple LED pulser
« Reply #1 on: September 26, 2025, 01:53:43 pm »
Interesting idea.
When I needed an LED flasher for a piece of equipment where the supply could vary from 6-14V I found that almost all of the common flasher circuits frequency varies with voltage.  Does yours?
I found this circuit where the frequency doesn't vary much and used with R=1.5M, C=1uF, and added 1k base resistors because simulation showed peak base currents higher than I liked:
https://web.archive.org/web/20190415225416/http://www.josepino.com/light/transistor_led_flasher
« Last Edit: September 26, 2025, 02:07:43 pm by Dan N »
« Reply #2 on: September 26, 2025, 02:22:28 pm »
Interesting idea.
Yes the pulse rate varies with bias voltage as this determines the charging current for the shunt capacitance. This circuit is about as simple as possible, requiring just 1 resistor, 1 cap, 1 transistor and the LED.
Best
« Last Edit: September 26, 2025, 02:24:25 pm by mawyatt »
The following users thanked this post: Dan N
Online jwet
« Reply #3 on: September 26, 2025, 03:01:08 pm »
Interesting thread.  The negative voltage stuff is just weird.
Note 555 type circuits don't vary with voltage, the charging current is an RC but the thresholds are 1/3, 2/3 of Vcc so track.  Modern CMOS 555's draw flea power.
Online themadhippy
« Reply #4 on: September 26, 2025, 03:46:29 pm »
bring back the lm3909
Online jwet
« Reply #5 on: September 26, 2025, 04:06:01 pm »
One the 3909 vector- I ran into this recently- Ken Sheriff reverse engineered one- fascinating hacking.
https://www.righto.com/2021/01/reverse-engineering-low-power-led.html
« Last Edit: September 26, 2025, 08:59:32 pm by jwet »
