Author Topic: Simple power supply hack  (Read 4847 times)
Offline hacklordsniperTopic starter
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« on: January 09, 2012, 05:31:29 pm »
Sometime ago i got these two power supplies (they were so cheap i could not resist)  Voltcraft RNG 1501 and 1502. The 1501 is 15 V -1 A and the 1502 is 15V- 2 A with adjustable current limiting.
Uploaded with ImageShack.us
I did not have time to check them out until now and compare them with a similiar Chinese power supply. The power supplies were originally built for German market so they should be better!
Check the heatsinking of Chinese unit compared to this one :
Also the units are properly grounded while the Chinese one is not. The Chinese one used a ultra thin power cable with a knot as strain relief  :). The German units even have heat resistant insulation on the wires. They also put heat shrink tubing on the mains switch and used a proper one (while Chinese one used a crappy switch, certainly life threatening). Altrough if the wire somehow got discconected it could easily contact the low voltage side and give you a shock.
The transformer in Chinese unit was burned so im powering it trough a wallwart. Im using single voltage and the display and electronics are powered trough a dropper resistor (original transformer has multiple windings for powering them). Compare the transformer removed from Chinese unit
I noticed the electronics are completly the same, there is even place for the current pot, so i just had to mod it :
Here is step by step to hack the power supply without current limiting to one that will have it...
Solder 2 missing jumpers:
J4 and J 5
Solder this bridge together
Remove R3
Remove this sticker carefully
Insert a potentiometer in a prepared hole and solder its wires to PCB where is as X1 - A (above the voltage pot):
Assemble and enjoy your free current limiting :)
Oh, the joy of sending various electronics to silicon heaven
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: Simple power supply hack
« Reply #1 on: January 09, 2012, 06:35:02 pm »
Great job and photos, thank you.  How do they regulate and ripple under load?
Best Wishes,
 Saturation
  • Country: hr
    • HackLordSniper
« Reply #2 on: January 09, 2012, 06:50:20 pm »
Uh um to be true i even did not bother to do any measurements except calibrating the display accuracy. I have much better power supplies for serious stuff, but i can do it if there is interest
