I am designing a circuit that measures the voltage of a DC load. This voltage
can be up to 12V, and I need to divide it by 4 so that an ADC can handle it. Also,
I want to minimize the current drawn for the measure.
To do so, I plan divide the voltage using a resistor divider with large values, and
feed the divided voltage to a single supply unity gain amplifier. I will power the
amplifier using a regulated 4V supply. I expect the amplifier to behave correctly
in [ 0V - 3V ], and up to a few KHz.
I am not used to choose amplifier ICs. Do you know an amplifier that would fit ?
This is for a home project, and I would spend up to 3$ in the amplifier (qtity 5).
Any advice and help is welcome !
Cheers,
