I'm feeding the clock input of a D-Type Positive edge triggered flip flop with a momentary switch on a 5v rail, using 100k ohm for debounce. For the most part, the flip flop won't change states - every now and then it will actually switch but for the most part, nothing.
I hooked it up to my DSO and measured my rise time to be 700 microseconds, so I'm thinkinging it's just too slow for the flip flip to register as a clock input.
Is there a way to speed up the rise time, maybe with a transistor fed from the switch? I'm very limited on space, working a 15mmx18mm board
