Hey,
I'm considering the design of a programmable LED mounted on cables. Each LED has its tiny PCB (a few mm each side), that is mounted along power wires (about 0.4 mm² each).
The data wire can be soldered, as it is daisy chained. For the two power wires, I'm looking into IDC transition connectors as they seem to have the advantage of not requiring wire stripping nor soldering.
The issue is that, as I'm exploring options, the connectors I find are either to large, or don't exist in 2 pins configurations.
So do you know any suitable reference?
Thanks for reading!
