Author Topic: small ISP connectors  (Read 6574 times)
Offline IDEngineer
Re: small ISP connectors
« Reply #25 on: March 10, 2020, 05:48:00 pm »
One downside will be higher board price if i remember correctly, they want more for cut in half plated areas.
Indeed, which is why I said "Its downside is increased cost of PCB fabrication for the castellated edge."
Offline mrburnzie
  • Country: cs
« Reply #26 on: March 11, 2020, 10:11:41 pm »
Create pads on the bottom of the board and have it sit on another board with small pogo pins.
That way you can place the pogo pins anywhere where you like. It's smd and can be placed near other components.
"Talk is cheap, show me the code"
Anyone need of freelance software/hardware developer, hit me up!
Offline AmperTopic starter
« Reply #27 on: March 12, 2020, 08:05:33 pm »
"in the field" ist not nailbed terretory.
Offline IDEngineer
« Reply #28 on: March 12, 2020, 08:09:07 pm »
Had another thought about the edge connectors and their castellated holes. When PCB's are panelized they scribe break lines so the individual boards can be separated after stuffing and reflow. I wonder if you could design the board with "traditional" holes, and a scribe line running through them, such that you could then just snap off the edge leaving the castellated holes as shown in the illustration. That might be cheaper than asking the board shop to actually route and plate the edge of the board... drilling and plating holes anywhere inside the boundaries is just "more holes".
Online ataradov
    • Personal site
« Reply #29 on: March 12, 2020, 08:11:56 pm »
No, it is impossible. Or it would basically cost the same. They normally would not even attempt to scribe over copper layer, much less interrupted cut over holes.
Alex
