Author Topic: Small OLED Recommends....  (Read 4710 times)
Offline rx8pilotTopic starter
« on: September 12, 2018, 06:14:35 pm »
Any recommendations for small OLED graphic displays that fit this general description:
Small - 100x30 pixels or so (a little more a little less is fine)
Small outline relative to the screen size
Any interface is workable - no need for any fancy onboard driver. Just need to be able to turn pixels on/off
Monochrome
Lowest cost practical while still being safe for a commercial release (ie: no random Ali Express)
Commonly available from safe distribution preferred.
Predictable product lifecycle
High-brightness sunlight readable is a bonus
Bonus if they are common enough to have some usable code support libraries for AVR or PIC MCU's
This company seems legitimate......
https://www.winstar.com.tw/products/oled-module.html
EDIT: Looks that they are a Taiwanese company. Not a problem as long as they are reliable.
« Last Edit: September 12, 2018, 06:22:06 pm by rx8pilot »
Offline kripton2035
Re: Small OLED Recommends....
« Reply #1 on: September 12, 2018, 06:51:24 pm »
I'm pretty sure you will be asked for the volume you need...
« Reply #2 on: September 12, 2018, 09:01:39 pm »
Yep.... about 500-1000 annual
Small qty.
Short and misplld from my mobile......
Offline krish2487
« Reply #3 on: September 12, 2018, 09:35:05 pm »
any specific reason why a SPI/I2C 128x64 oled module wouldn't do??
you might even get a decent price considering the quantity requirement??
they already have a controller on board so finding libraries will be fairly easy.. IIRC Adafruit has something for that as well..
they are fairly mature and easily available..
Ok, you don't need to go aliexpress for them..
infact the company you linked to has a fairly common one found floating on the Internet..
https://www.winstar.com.tw/products/oled-module/graphic-oled-display/0_96-oled-i2c.html
I am just curious as to the very specific requirements for the OLED, that's all.. especially since a more "standard" one is very common with very close specs..
Hope this helps!! :-)
If god made us in his image,
and we are this stupid
then....
« Reply #4 on: September 12, 2018, 09:54:11 pm »
I am specifically looking for a totally normal, standard part. I2C or SPI is fine - like I said 'Any interface is workable'.
As a ballpark - I wrote 100x30 but 128x32 is a common arrangement and just fine.
The desired placement is on the edge of an enclosure. The goal is to find a display that has as little above/below the active screen area as possible as the physical hight if the display will likely determine the final height of the enclosure. Hoping to have as thin an enclosure as practical.
Adafruit is not an OEM dealer (at least not a good one) - they make kits to experiment with. At this qty level, I would be going through a distributor of some sort. Not nearly enough to go factory direct, but far too many to go with Adafruit. I need to buy these for at least a few years with some confidence. If the part changes or is discontinued - it will force a re-design. Not good.
Offline wholder
    • Wayne's Tinkering Page
« Reply #5 on: September 12, 2018, 10:45:54 pm »
The following users thanked this post: oPossum
Offline Mr. Scram
  • Display aficionado
« Reply #6 on: September 12, 2018, 11:52:06 pm »
Check out: https://www.buydisplay.com/default/oled-display
Wayne
That looks like a fairly typical Chinese outfit, with the pros and cons those come with. I'm not sure they can guarantee availability.
« Reply #7 on: September 14, 2018, 10:37:40 pm »
I got a response from the Winstar US office with data and a quote. The pricing is better than expected, but the leadtimes for small qty is 11-16 weeks. I have asked them if there is a list of stock products that I can design around to prevent a 3-month lead-time.
I looked at the options from Newhaven. They are physically too big relative to the viewable screen area and drastically more expensive. Kind of pushes them off as an option.
« Reply #8 on: September 14, 2018, 11:32:13 pm »
Since EastRising has the same product line (same glass, same chip) of WinStar, you can prototype with theirs.
Oh yes - I see. Same everything, same controller. Insane 1/pc pricing!!!
Offline dcarr
« Reply #9 on: September 15, 2018, 01:55:34 am »
Insane in a good way?
« Reply #10 on: September 15, 2018, 04:12:37 am »
Lower cost than I expected.
Offline Kjelt
« Reply #11 on: April 11, 2025, 09:40:31 am »
Meghan did you check the date of this post ?
7 years........ :=\
