Well, I'll have to move on as it doesn't seem we have similar requirements from servos or steppers. I'm talking factory floor equipment - 200GPB won't buy me the cables between the motor and the drive. In real life, most equipment can't take advantage of the performance of high end servos for too many reasons to mention here. I've no idea where your experience exactly rests but my some 80 or so retrofits taught me I must be very careful before jumping into the latest fad. And linear motors were WAY cheaper than servo+C3 ball screw 20 years ago. It was the horrible cogging and the holding torque issues which switched me off. Bottom line is that the R&D teams of large machine tool manufacturers are surely cleverer than you and I put together and squared and they still manage to blunder grievously like EIGHTY percent of the time.
I'm getting tired of this, but one more reply to your ill-thought out responses.
This is far from a 'latest fad' it's tried and tested units, there are over 3 million axis out there using these drives from this manufacturer alone.
Cogging is not an issue anymore these days, modern drives have anti-cogging calibration that is impressively functional.
I'd strongly suggest you try it before you knock it. Why not contact the Elmo representative in South Africa, they could give you a good rundown of just how much of a benefit these modern servos can add to application.
I only speak so highly of Elmo because I haven't seen a damn servo-drive better then what they have shown off.
You can't claim experience with apples and the ability to judge them simply because you have tried a lot of pares and oranges.
Well, it's clear to me now that you haven't seen many drives or actually used any. I looked over their site, couldn't find any documentation and even the installation manuals were password protected. There is practically NO technical information available - it's all vague talk about "performance". The general look of the drives / motors and CONNECTORS ( !) indicates a CHEAP product.
Take a look at the capabilities of a mid range drive like Omron/Mits/Panasonic R88D-KT series and then talk. Notice the 2Khz speed response. Looking over their marketing spiel I see absolutely no extra capability from Elmo drives/motors but I see a HUGE amount of stuff they don't do.
But in order to make you happy I'll get an Elmo drive and motor and test it against a Panasonic R88 drive and post the results here. That way we'll see what's the apples and what's the pears. Please PM me your contact details - if the Elmo loses, I'll send you the Invoice.
Amusing you say I haven't seen many drives or 'actually used any' considering my actual job is configuring, setting up and testing Servo drives. Selecting, installing and providing technical support for servo drives is there about half my job.
Also I'm pretty confused by you saying you see a 'huge' amount of things that the Elmo drives don't do. Mind pointing out some?
A lot of the information is locked up with an account as it is propriatory information and they like to have some level of control as to who has access to it.
I'm more then happy to share with you some of the specs:
Current closed loop bandwidth exceeding 4kHz
Current / Torque Sampling rate: up to 25kHz
Velocity Sampling rate (up to 10kHz, can be increased to 16.67kHz)
Position Sampling rate (up to 10kHz, can be increased to 16.67kHz)
Electrical commutation frequency: up to 3kHz
S-curve profile smoothing
Cogging compensation
Duel Loop Operation supported by Autotuning
On the fly gain scheduling of current and velocity
Automatic Commutation alignment
Automatic motor phase sequencing
Advanced filtering (low pass, notch, lead/lag, general biquad)
Current loop gain scheduling to compensate for bus voltage variation
Gains and filter scheduling vs. position for mechanical coupling optimization, speed and position tracking errors
Velocity gain scheduling using high order filters.
Output compare repetition rate: 13kHz
Motion modes: PTP, ECAM, Follower, Duel Loop, Current follower
1us latancy on output compare.
Full encoder support (including several propriatory ones (ask and recieve from them)
I think that exceeds anything else you can suggest from other products.
Far from cheap, I've seen inside these drives, they are damn beautifully made, the power stage is on a custom ceramic substrate for some of the higher power ones.
they have developed their own ASIC gate-driver that allows extremely efficient switching
I can't disagree there are some things that sound like 'marketing wank' but I'll be damned it's all true.
Check out this drive, 4kW and only 22 grams...
http://www.elmomc.com/products/gold-twitter-servo-drive.htmAnd yes, I called bullshit with them when I first saw it, but they actually show it running at full power on their stand at some exhabitions.
If you were in the UK, I'd be happy to organize sending you one of the servo drives and a motor to test it with, but South Africa doesn't have the best reptuation. Why not ask the local Elmo Sales office there if they could offer a demo kit to play with or something similar?
EDIT:
Here, I've uploaded this just for you:
It's not continuous, but it's the best demo you can do without a significantly large load, even then, it's quite a nice show considering the inertia of that huge motor and the size of the drive.
Another impressive feature I forgot to mention is that you can put drives in parallel for the same motor (you use a special cable between 2 of the output / input ports and use a duel wound motor) that way you can have a seriously small drive form factor. For example, one of the customers uses their HV Drums, 2x 65kW units running a 120kW duel wound motor.
