If it is the device labelled as FRD01 or FRD02 then those are fast recovery diodes, typically 1000V rated at 5A or so, and with fast recovery. Used to keep the FET body diode from switching on when the fet is turned off, as the body diode is a slow recovery one, and having it off all the time with the fast recovery diode handling the current ( equal to the FET ratings typically) means it will be able to turn on faster.
