1) Does anyone know if there is a "gullwing" tip for a Weller WESD51 soldering iron? If not, what would be the next best Weller (WESD51 compatible) tip for SMD drag soldering?
Doesn't appear they make a dedicated tip (gull wing, spoon, ...), but you can use others.
Chisels, hoof types, and knife shapes will all work (just need to develop your technique). Hoof would probably be easiest (they're calling them single flat, such as the ETDD). Between a chisel or knife, the knife should be a little easier IMHO.
Photo of an ETDD (largest hoof offered):
2) I've been using Kester 48 lead-free RA solder .031" and it works pretty well but I'd like to try the same or something similar in .020"; Kester makes this in a 1lb reel but I'd like to try it in a smaller package first - anyone know of such a product (Lead Free RA .020 in a package one ounce or less)? From Kester would be great but I'm open to other recommended brands.
If you're set on Kester 48 broken down into smaller packages, it looks like you'll have to resort to eBay (
15ft. of Kester 48, 66 core, SAC305 alloy).
If you can be more flexible on flux, then this might be of interest
2 oz. SAC305, no-clean from SRA.
But why not use lead based solder instead?
It's a lot easier to work with, and it solves tin whiskers (one less thing to chase down
