Author Topic: Smith Chart  (Read 3217 times)
Offline bostonmanTopic starter
Smith Chart
« on: February 08, 2023, 04:12:34 am »
Although it's been many years since I learned about Smith Charts, I've never understood how to look at one and understand if it represents a good circuit or a bad one.
We just dotted the associated points and connected them, and, I've seen them in datasheets, but again, never grasp the concept of whether one is bad or good.
Is there an easy way to tell?
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Smith Chart
« Reply #1 on: February 08, 2023, 12:32:01 pm »
I don't think there's a simple answer to that question - "good" or "bad" depends on what you're trying to do. :)
Exactly.
Same answer as measuring a voltage with a DMM or inspecting a waveform with a scope. Is what they are representing on their screens "good" or "bad"? It depends on a lot of things that you have to take into account with the information you are looking at. So in a simple example if you are looking at what you believe is a "pure" resistance and you also see inductive reactance on the smith chart, then you must determine why it's showing that. Is that "good" (or in other words explainable) because the resistance leads are presenting inductive reactance, so it's what you should expect - it's acting as it should be in this circumstance. Or perhaps it's a SMD resistor and the resistance element is poor, so in that case you know the result is "bad"?
Re: Smith Chart
« Reply #2 on: February 08, 2023, 04:08:02 pm »
Good points, I hadn't thought about that aspect before posting my question.
Would I have been better off asking whether a large circle is more/less resistive or inductive? I mean, if a hundred Smith Charts were in front of you, and you wanted to pick one based on a specific criteria, could it be done easily enough?
Maybe a 50ohm load to use a practical example.
