Author Topic: Smps ripple current definition  (Read 1084 times)
Offline sahko123Topic starter
  • Country: ie
« on: April 09, 2022, 09:55:14 pm »
I'm currently designing a 120ish watt smps for which I a tiny transformer (only for a micro and the smps controller) in calculating the inductor value I need the ripple current through it.
Would the ripple current be defined as the largest peak to peak current draw of the power supply, roughly 5amps pk to pk for a 24v output for a 340vdc input, since the load is a pwm controlled soldering iron (jbc t245). So do I take 5amps as the pk to pk ripple current through the inductor?
Asking for a friend
Offline Terry Bites
Offline bson
Re: Smps ripple current definition
« Reply #2 on: April 11, 2022, 06:44:17 pm »
It's the standard deviation.
Online TimFox
« Reply #3 on: April 11, 2022, 07:22:08 pm »
Otherwise known as the rms value of the varying component.
