Here is a model that illustrates phase-controlled soft-start:
The model works by generating the line voltage as a function of time. Time is a special parameter in SPICE meaning the current simulation time.
A cosine ramp is also generated using a modulo function. The cosine ramp needs to represent 0-180 degrees or Pi radians.
The signal alpha represents the firing angle.
The switch is turned on if the alpha is greater than the cosine ramp.
I have attached the LTspice model.
Hint: find and read the GE SCR manual which was first published over 50 years ago. This is the best resource for this type of circuit.
In modern times this could be implement with a phase-control solid state relay and small micro.
Regards,
Jay_Diddy_B
[ Specified attachment is not available ]
