Author Topic: SOIC package current capability  (Read 2964 times)
Offline hamdi.tnTopic starter
  • Country: tn
« on: November 30, 2014, 04:06:30 am »
Hi everyone, so i was looking around in farnell for some hall effect sensor and i so this ACS758 it's SOIC package and it claim to handle 30A ... the more bizarre for me is this PFF package and it's suppose to take 200A !!!! is that possible for those pin !
Offline martinjaymckee
Re: SOIC package current capability
« Reply #1 on: November 30, 2014, 04:31:29 am »
The PFF package route the current through the large ( bar-like ) pins toward the top.  According to the datasheet, the resistance of this current path is 100 micro-ohms.  At 200A, that would give a total voltage drop of 0.02V, and a total power dissipation of 4W.  The thermal resistance is 7 degrees-C/W, so at 200W, its temperature should increase about 28 degrees-C.  So, yes, I would say that it's entirely reasonable to say it can handle the 200A -- with the caveat that you are able to connect wires to this thing in a reasonable manner that doesn't have substantially more resistance ( which is no small feat ).
The SOIC package is similar.  It has a resistance across the load path of 1.2 milli-ohm.  Short answer -- these aren't standard SOIC packages with pins and bonding wire.  Trust the datasheet, they work.
Martin Jay McKee
Offline Marco
« Reply #2 on: November 30, 2014, 04:32:29 am »
The SOIC has a slab of copper internally and the leads are short and it uses 2 of them for each terminal.
As for the PFF, the leads are 6mm2 even if the connection is made at the extreme end (ie. 10mm) that will only add an extra ~200 uOhm.
Offline qwaarjet
  • Use your imagination and pretend its linear.
« Reply #3 on: December 01, 2014, 04:29:43 am »
I have used both of those packages in various projects  never had any problem with heating even near the current limits.
  • Country: tn
« Reply #4 on: December 01, 2014, 07:13:03 am »
that's reassuring  :P anyway i added the PFF one to my design , will try it soon, thanks :D
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5 on: December 01, 2014, 07:59:39 am »
LFpak mosfets are also capable of high currents. Through 3 pins similar to soic.
Interesting document:
http://www.nxp.com/documents/leaflet/939775016838_LR.pdf
