Author Topic: Solid State Amp Project  (Read 15524 times)
Offline angelothewolfTopic starter
« on: May 02, 2013, 03:52:11 am »
Hi there! Im planning to make an small 100W guitar amplifier head, small as possible with 100W of power. i made a few TIP142/147 amps with this PCB. but i wonder what improvements can i do to this circuit, or if there is another way to get 100w from that type of size/complexity amp,,,
Offline NiHaoMike
    • Facebook Page
Re: Solid State Amp Project
« Reply #1 on: May 02, 2013, 04:28:02 am »
TI makes some chips that will do as much as 600W in a size of a quarter and need only small heatsinks, as long as you're willing to solder surface mount.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline Tube_Dude
  • Country: pt
« Reply #2 on: May 03, 2013, 02:55:49 am »
Hi
Put a 1K resistor in series with the input electrolytic capacitor and a Zobel network at the output of the amp. Both actions will improve the amplifier stability...
Edit: Put a 100K resistor in parallel with the 100 pF capacitor at the input. It will charge the 10uF electrolytic input capacitor, in absence of any source connected to the amp.
« Last Edit: May 03, 2013, 03:01:00 am by Tube_Dude »
Jorge
