Author Topic: Somatosensory Smart ES120 Screwdriver - Gospel of DIY Enthusiasts  (Read 6944 times)
Offline MiniWareTopic starter
  • Country: hk
Product Info: http://www.miniware.com.cn/?product-244.html
Out-of-Box Experience
ES120 somatosensory screwdriver is designed andmanufactured by e-Design, and the main
highlights of this screwdriver are itsexquisite metal shell, OLED display, somatosensory
turning and multi-torqueoptions, these highlights are integrated together into a piece of
craft-levelmini power tool.
Performance Parameters
With weight of 130g, built-in 3.7V single-celllithium, no-load maximum speed of 170r / min,
torque up to 2.5 / 20kgf-cm, useof 4MM hexagon bits; and you can manually upgrade the firmware.
A portable storage bag is presented with the tool,ES120 can just be fitted in. Only the space
for carrying screwdriver bits is alittle less, there is still space next to it, and you can DIY
in spare time, itis expected to insert 10-12 screwdriver bits.
Appearance
The body of the tool can be described as exquisite,the hard texture of alloy shell is better
than that of aluminum, making thetool more durable.
Let's get into more details of the appearance, itsreticulate knurling plays a non-slip role and
ensures that the hands won't bepricked. The performance of ES120 in the details is not inferior
to thehardware of other major brands.
On top of ES120 screwdriver,is the charging interface and also the data interface, the firmware
of thescrewdriver can be updated through connecting to the computer. If there isrequirement for
an upgrade, you can connect the ES120 screwdriver under offstate to the computer, press and
hold the ES120 button to copy the firmwareinto the USB flash drive.
The specification ofbit socket is 4mm, which can be compatible with a variety of 4mm
hexagonalbits, with strong magnetic adsorption. With self-locking device, you canmanually use
the screwdriver, in case of firmly secured screws which cannot beloosened under electric mode,
you can manually loosen and then enable theelectric mode.
Functions
What is distinguished about this screwdriver is toachieve the direction and speed control
through the built-in gyroscope, theadvantage is that it is unnecessary to set a mechanical
turning switch for thetool body, all the functions can be operated with a single key, and can
achievethe magical somatosensory control effect. Press the button for three times topresent the
5-speed option menu, where you can adjust the torque, commonly use1, 2, 3 and 4, Gear A is for
the automatic mode, the speed of the screwdriverincreases as the rotation angle increases, the
speed of screwdriver bit can becontrolled through slightly turning of the tool body.
Somatosensory Control for Direction of Rotation ofBits
Only by pressing and holding the button of ES120and turn the screwdriver itself as rotation
axis, the rotation direction of thescrewdriver will be consistent with the direction of
turning. As for thetriggering angle of rotation, the minimum control sensitivity is 2
degrees,that is, as long as the screwdriver is turned for 2 degrees, the controlcircuit can be
triggered.
ES120 screwdriver provides a customization for thisfunction, access to the USB data cable under
off mode, short press the button,the computer will identify the USB flash drive; open
config.txt in the USBflash drive, showing the following contents:
StartAngle=2 # (2~10) start angle of braking, if itis set to 2, then the press button will
rotate for 2°
Gear=4 # (0~4) The set gear upon starting of themotor, 0~4 corresponds to Gear A~4
MotoTimeCont=0 #ReadOnly Motor use time, cannot bechanged
Ver=1.1 #ReadOnly Version number, cannot be changed
The following figure shows the control for turning,the gestures for control in the figure
changed more obviously, this was tobetter demonstrate the control effect, in actual use, you
only need to turn thescrewdriver very slightly, the response will be very sensitive.
Thisscrewdriver has a memory function, press and hold the button under the standbyinterface,
keep stable for half a second, the screwdriver will rotate, and thedirection of rotation will
be that of the last use; this function is veryconvenient for the users of frequent use of the
screwdriver.
Somatosensory Control for Speed of Bits
Gear A is for automatic mode, in addition toachieving somatosensory control of rotation
direction, it can also achievesomatosensory control of speed, the main role of this function is
not forshowing off, it can not only guarantee the speed of driving, but also canprevent the
threads of screw from being broken.
Look at the demonstration in the figure, although theaction is still exaggerated, the actual
rotation sensitivity is of about 2degrees. The speed control process is very interesting, from
slow to fast, youcan do whatever you want, it is more like manually turning the
motorcyclethrottle. When the ES120 is turned at the slowest speed, the rotation speed ofbit is
adjusted to the minimum, and if the speed of turning is increased, therotation speed of the bit
will gradually increase.
If you want to useES120 smoothly, the two screwdriver bits presented together with the tool
arefar from enough, it is necessary to buy a multi-function bit set kit.
The genuine parts areprecision bits of "Labear", a Taiwan brand, made of 8660Nickel-chromium-
molybdenum alloy steel with high hardness, the bits areslightly magnetic, such magnetic may
come from part of the screwdriver bit basewhich has strong magnetic force, in short, it is easy
to use, you can use thisfunction to absorb screws, the absorption is good, it can help you save
timeand effort.
Purpose
With the multi-function bit set kit, ES120 can almostbe used for the entire digital sector: the
lens, the players, mobile phones,etc., ES120 can be used wherever there is a screw.
Here are a few commonapplication scenarios to illustrate the use of this screwdriver, the
majorityof mobile phones on the market, including Apple phones, most screws for mobilephone
assembly are TORX screws, such screws are more sophisticated, although ofsmall size, but can
have around 20 threads, to tighten or loosen them manuallyone by one would be quite laborious,
especially for maintenance professionals,handling such screws every day can be considered as
physical labor.
Phillips screws onmusic player can easily have broken threads, especially in case that
thescrewdriver bit is harder and does not stop rotating in time, the more powerfultorque will
drive the bit to rotate a few more turns, which may destroy thescrew.
As for the slot headscrews on electronic watch, the advantage of having many screwdriver bits
canbe reflected now, no screw cannot be unscrewed, such screws are of very smallsize and are
also used on the glasses.
Potential Mining
As for the electric screwdriver, torque is the datathat will be most concerned about; the data
parameters proclaimed by themanufacturer cannot well express its power, the torque value cannot
be learnedthrough tightening the screws either. I personally feel that drilling is theintuitive
method to show and verify the torque.
As differentmaterials are of different densities, the minimum torques required to drillthem are
also different. The following example is to drill wood with ES120screwdriver, as the is very
short, we find a paint brush with diameter of 1 cmto use for this test, the brush holder is
very hard, ES120 can easily drillholes on the wooden brush holder.
Drilling Iron Sheet
It is also very easy for the screwdriver to deal withmetal can, adjust the torque to Gear 4,
press the body of the screwdriver with force,in the whole process, accompanied by the friction
noise of drill bit and metalsheet, the drill kit is rotating, while the motor does not enable
overloadprotection due to too much resistance, it can be seen that Gear 4 is enough tocope with
such metal sheet.
Double-sided PCB Multilayer Circuit Board
As for DIY of circuit board, you need to manuallydrill holes in the CCL. ES120 can easily drill
through such double-sided PCB ofhigher hardness, which shows its significant motor performance
and drivemodule, the quality of the tool is very applicable for the DIY enthusiasts.
Conclusion
Each tool will have its specific use, and the use ofES120 is only targeted at small size
screws, it is suitable for assembly anddisassembly of a variety of sophisticated small
equipment. It has the followingadvantages: small size, high torque, exquisite shell, adjustable
torque andsomatosensory control. Hope thisscrewdriver will become the classic in the classic
DIY tools.
ADDED BY MOD: Miniware manufacturers account.
Offline Dubbie
Re: Somatosensory Smart ES120 Screwdriver - Gospel of DIY Enthusiasts
« Reply #1 on: April 21, 2017, 02:53:08 am »
LOL
in before the banhammer.
Online ataradov
    • Personal site
« Reply #2 on: April 21, 2017, 03:34:09 am »
Somebody wasted a lot of time designing this piece of garbage :)
Alex
Offline basinstreetdesign
« Reply #3 on: April 21, 2017, 04:16:22 am »
It is what it says in the second picture, on the box:
"Electric Screwer"
 ;D
STAND BACK!  I'm going to try SCIENCE!
Offline thm_w
  • Non-expert
Offline amyk
« Reply #5 on: April 22, 2017, 12:38:35 am »
"somatosensory"? "Of or pertaining to the perception of sensory stimuli produced by the skin or internal organs" :o
It apparently absorbs screws too. Maybe that's the sensation they're referring to... :wtf:
Offline helius
« Reply #6 on: April 22, 2017, 01:16:02 am »
It's clearly referring to the use of the accelerometer to set the speed and direction. While unfamiliar in English, the term isn't wrong.
This feature is found in some larger drill-drivers from DeWalt and B&D.
Online all_repair
« Reply #7 on: April 22, 2017, 02:38:16 am »
I was waiting for review of ES120 here for a while, but nothing came out.  I have bought from Taobao but going to take a while to reach me through sea.  They also make TS100 soldering iron (probably one of the best portable soldering iron, reviewed by Mike Harrison before).
Offline ober
« Reply #8 on: June 22, 2017, 08:10:11 pm »
I have one of those, and the mechanism surprisingly makes quite some sense.  However, my ES120 has a defect in the socket that takes the 4mm bits:  Normal 4mm hex bits cannot quite be pushed through to the magnet as there is a circular ledge in the way, so they don't stick.  (The magnet is powerful enough; this is easily shown by putting in a bit upside down -- even the small tip will stick to the magnet quite well.) The bits also wobble a bit too much for my taste (as also can be see in the video above).
Offline BBBbbb
« Reply #9 on: June 22, 2017, 08:38:26 pm »
You could have put some effort into formatting this copy/paste text.
I just have one question:
Is it an IoT? If it's not online we really shouldn't consider it :-D
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #10 on: June 23, 2017, 12:11:02 am »
Cool design. I love it.
But I have my handy IKEA FIXA 7.2V cordless electric screwdriver/drill already...
