Author Topic: Source for this gold binding post?  (Read 9255 times)
Offline EEVblogTopic starter
« on: May 27, 2013, 04:49:42 am »
Does anyone know a source for this gold binding post? (apart from Altronics)
http://www.altronics.com.au/index.asp?area=item&id=P2000
The one on the left in the photo below with the raised panel keying is the Altronics one I want.
The one on the right with just the round thread is the only one I have been able to source elsewhere after extensive searching. But I need the one with the panel keying.
No, Altronics will not tell me who their source is, and charging too much, and have ridiculous lead times for bulk.
Yes, I have tried countless Alibaba sources, but have had no luck.
Thanks.
« Last Edit: May 27, 2013, 05:09:25 am by EEVblog »
Online Rasz
    • My random blog.
Re: Source for this gold binding post?
« Reply #1 on: May 27, 2013, 05:09:19 am »
why do you need keying? Loctite is not enough?
« Reply #2 on: May 27, 2013, 05:10:14 am »
Because it's 100% effective, forever. And no extra production step required.
Offline iloveelectronics
  • Country: hk
« Reply #3 on: May 27, 2013, 05:58:50 am »
Dave, the pictures don't show the details very clearly but the seller says they do have the panel keying bit: http://item.taobao.com/item.htm?spm=a230r.1.14.219.2NfFhM&id=13198578895&_u=roemap3cb1b
I can order a couple of these to have closer look if you like.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline fpliuzzi
« Reply #4 on: May 27, 2013, 12:03:42 pm »
Franky,
I found this enlarged image of the binding posts, via your supplied link. Maybe the photo will supply enough detail for Dave.
Regards,
Frank
  • Country: hk
« Reply #5 on: May 27, 2013, 12:41:53 pm »
I went ahead and ordered a few anyway, just because I'm curious ;D They are cheap enough to be dumped into the parts bin for the rainy days even if Dave doesn't want them   :P
Offline olsenn
« Reply #6 on: May 27, 2013, 12:47:41 pm »
Those actually look like RadioShack binding posts... of course I'm not sure if they still sell them. Try searching futurlec.com or even mouser/digikey
Offline edavid
« Reply #7 on: May 27, 2013, 09:57:16 pm »
So, out of curiosity, what is it about those binding posts that you like, other than the keying?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #8 on: May 27, 2013, 10:03:06 pm »
Glue of any sort is a PITA for production unless you have a fully automatic dispensing & placement process - getting the right amount in the right place consistently, spillage, curing time etc. all slow things down and open up multiple error possibilities.
Day Job: Mostly LEDs
Offline ConKbot
« Reply #9 on: May 28, 2013, 05:11:21 am »
That and loctite only prevents rotation of the nut relative to the post. The keying with the D on it makes sure the alignment of the hole though the binding post never changes, and is always the how you intended.  Binding posts that spin when you crank down on them by hand =  :--
Offline poorchava
  • Troll Cave Electronics!
« Reply #10 on: May 28, 2013, 06:54:32 am »
Using adhesives also has a downside, that manufacturer has to perform chemical safety assessment and all the related stuff (which varies from country to country). Of course they will happily do that for you, and same as happily charge you for it in this form or another.
Offline amc184
« Reply #11 on: May 28, 2013, 08:40:18 am »
Bennic is probably the OEM, and they do take orders directly (though I'm not sure what the MOQs would be like).  I think BP11, BP18 or BP18U will be the ones you want, with the D suffix for keying.
  • Country: hk
« Reply #12 on: May 29, 2013, 05:13:46 am »
Here's a close-up picture of the binding posts I ordered from Taobao. They do have the panel keying part.
Offline BravoV
  • +++ ATH1
« Reply #13 on: May 29, 2013, 05:32:22 am »
Teaser ... guess what Dave is up to with this things, yep, he posted the sneak peek on at the "Lounge".  ;)
« Reply #14 on: May 29, 2013, 06:09:06 am »
Thanks, yes they look like the ones.
The key on the Altronics ones are 5.13mm x 3.93mm
Are the Taobao ones the same?
I presume it's some sort of defacto standard of sorts?
That matters because the PCB cutout has to match that and not be too loose.
« Reply #15 on: May 29, 2013, 06:36:36 am »
Yep, the BP11 looks like the one. Great to have an actual reference, thanks.
  • Country: hk
« Reply #16 on: May 29, 2013, 12:42:22 pm »
The ones I've got measure 5.37mm x 3.97mm. Close enough?
« Reply #17 on: May 29, 2013, 12:45:28 pm »
Yup, thanks!
  • Country: hk
« Reply #18 on: May 29, 2013, 01:03:33 pm »
Yup, thanks!
I'm sending you 2 pairs tomorrow. Should be in your mailbag some time next week :)
Offline ddavidebor
    • Sideband
« Reply #19 on: May 29, 2013, 01:10:39 pm »
It's time for another mailbag, you've a lot of box to open!
Currently working on the future of Altium library management https://getsideband.com/
Need Altium Designer Libraries? Check out https://getsideband.com/libraries (35k symbols, 34K footprints)
« Reply #20 on: June 13, 2013, 06:18:28 am »
Got'em thanks!
Perfect fit.
So would I be able to buy these through you in volume?
And should I plug your ebay store?  ;D
  • Country: hk
« Reply #21 on: June 13, 2013, 08:29:04 am »
Glad they fit well! Yes, I can help you order in volume too. Just PM me your requirements (volume, time, etc) and I will see what I can do.
No need to plug my eBay store just because of this. I try not to come across too much like a “spammer” who's here just to sell :) In fact, I'd much rather have more time to do some learning and experimenting myself too!
Got'em thanks!
Perfect fit.
« Reply #22 on: June 13, 2013, 11:11:35 am »
It's in your footer anyway  ;D
