Buongiorno Signore the 1 gHz Chinese SA may not be needed....
Rather then measure and then patch up a poor design and layout after the fact.
easier to learn good PCB layout and shielding practice for EMI compliance and design the PCB from the start,
Just a scope and DIY loop probes can see the EMI. Conducted 100/150 kHz...30 MHz, radiated depends on the device class and power.
Actual compliance and qualification of a device needs an extensive lab for both conducted and radiated EMI.
Finally any SA will have a learning curve.
Ciao
Jon
