Author Topic: SPICE model collection  (Read 3826 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
Seven Transistor Labs, LLC
The following users thanked this post: BravoV, MagicSmoker, TheUnnamedNewbie, iMo, Glenn0010, schratterulrich, SiliconWizard
Re: SPICE model collection
« Reply #1 on: November 25, 2019, 11:08:12 am »
Added:
https://www.seventransistorlabs.com/Modeling/SPICE/HI0603P600R_NL.ckt
with comparison plot:
https://www.seventransistorlabs.com/Modeling/Images/HI0603P600R_Overlay.jpg
Corrected the MI1206L391R_NL.ckt part and added comparison plot as well.
I suspect the error in these parts may simply be error in the flux calculation in my generating tool.  I may write a page about these some day to show how this works.
A reader e-mailed that the "^" operator doesn't work in LTspice.  I'm in the process of changing the syntax in all models to use PWR(), * or SQRT().  (Well, I've changed them already, that's the easy part, but I want to actually check them before updating the site...)  If you are using LTspice, you may want to give this a check.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #2 on: November 25, 2019, 11:49:01 am »
Tim, awesome that you are doing this. What is your idea here - only host models you use (and have vetted?), or create a general spice lib where people can 'submit' components?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Miti
« Reply #3 on: November 25, 2019, 12:04:30 pm »
Wow, great collection Tim!
I was thinking the same thing as Newbie, do you intend to create a collection with external contributors, or just sharing yours?
Just the other day I was trying to simulate a crystal filter and the crystal model in ltspice needs lots of parameters that I couldn’t find in the datasheet of my crystal. Do you know how to simulate crystals?
Thanks,
Miti
Fear does not stop death, it stops life.
« Reply #4 on: November 26, 2019, 01:50:43 am »
Just mine, yeah.  Obviously, I want to avoid anything that's copywritten (the MCP6561 may be questionably fair use?) or proprietary (i.e., that I wrote in the course of a project).  Also, publicly available models aren't interesting (you all know how to search manufacturers' websites, right?..).
Suppose I can add links to other sites.  Could host others' files, just put them in a section, with a relevant description (including licensing, presumably something open?).
I want to add detail to a few; it feels like the S/PMETERs deserve an example.  That would be an Altium project demonstrating them: PrjPcb, SchDoc, SchLib and ckt in a ZIP.  I think I want more example material on my site, and little play/test circuits are an easier way to go about that.
« Last Edit: November 26, 2019, 01:53:21 am by T3sl4co1l »
« Reply #5 on: November 26, 2019, 01:14:58 pm »
Speaking of nonlinear ferrite beads, this looks interesting:
https://www.researchgate.net/publication/224597964_Measurement-Based_Equivalent_Circuit_Model_for_Ferrite_Beads
It's still high level though, not like they give SPICE code.
« Reply #6 on: January 04, 2020, 11:15:53 am »
Added an example project and some detail to these models:
https://www.seventransistorlabs.com/Modeling/PMETER.html
Also reviewed the Coilcraft models and improved compatibility.
