Author Topic: Split groundplane, why?  (Read 2607 times)
Offline edgelogTopic starter
« on: December 02, 2017, 06:22:52 pm »
I'm fiddling around with a broken Razer Mako speaker system and one strange (to me) layout got me wondering. The ground plane is split over a part of the board with a few decoupling capacitors across the gap. I'm just wondering why they did it this way. Anyone can clue me in?
Since it's a speaker system, all signals are in the audio range, nothing RF here.
« Last Edit: December 02, 2017, 06:26:36 pm by edgelog »
Offline elal1862
  • Jeri is my middle name
Re: Split groundplane, why?
« Reply #1 on: December 02, 2017, 09:01:58 pm »
So you've heard about ground plane inductance, but you forgot about ground plane resistance - which isn't negligible if you're dealing with a couple of amps of return current (from the speakers back to the power amp, when playing at full blast).  You don't want that current to take a shortcut across the input stage!
« Reply #2 on: December 02, 2017, 09:06:02 pm »
Yes, that makes sense. Thx.
Offline cat87
« Reply #3 on: December 03, 2017, 10:11:50 am »
If you look at it, the planes are not  actually split. They have continuity. It's more like they just branch out. This split is done to keep dirty noisy ground currents from the power section away fron the input ground.
Offline janekm
« Reply #4 on: December 03, 2017, 10:21:47 am »
I'm curious about those speaker terminals, could you post some pictures of those? Seems like an unusual footprint!
« Reply #5 on: December 03, 2017, 11:07:41 am »
The main unit contains the woofer, connected by leads soldered to the middle of the main board. Two satellite speakers each contain a midrange and a tweeter. The connection between the main unit and the satellites is with RJ45 connectors and pretty heavy flat cables. I took apart one of the satellites which showed me that the midrange and the tweeter have their own connections to the main unit, so the frequency filters are in the main unit.
« Reply #6 on: December 03, 2017, 11:18:09 am »
Dave has done blog on current paths on a pcb and while the ground plane is connected further down the pcb, the large speaker current will not find its way back the input stages to cause noise problems. Remember electricity will always take the shortest route if it can and that is why the ground is split but has decoupling caps across the divide to allow access signals across but block out the high power dc currents.
Sent from my SM-J510FN using Tapatalk
