EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Spring Plunger Component Name?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Spring Plunger Component Name? (Read 3330 times)
mbush91
Newbie
Country:
on:
June 02, 2017, 02:33:57 pm »
Hello All,
I have been googling for hours to no avail. I am looking the name of a mechanical component which I have seen used before. The component will be used on a production test rig to depress a tactile switch. The component consists of a spring loaded metal cylinder nested inside another cylinder. The inner cylinder sticks out of both ends so when the outer cylinder is mounted it allows the entire inner cylinder to be pushed downward then springs back to the normal position. The whole thing is maybe 3mm-5mm in diameter and maybe 15mm - 20mm long?
I have attached an image that I quickly modeled of what I am attempting to describe. It shows the component in the uncompressed (normal) position. When the top is pushed down the entire inner cylinder moves with it.
If anyone knows what to call this thing to find it for sale I would really appreciate it!
Logged
MagicSmoker
Super Contributor
Country:
Re: Spring Plunger Component Name?
Reply #1 on:
June 02, 2017, 02:37:11 pm »
The informal name is a pogo pin.
See, for example, this selection at DigiKey:
https://www.digikey.com/products/en/connectors-interconnects/contacts-spring-loaded-and-pressure/311?k=pogo+pin&k=&pkeyword=pogo+pin&pv1989=0&FV=ffe00137&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
Logged
mbush91
Newbie
Country:
Reply #2 on:
June 02, 2017, 02:57:13 pm »
Sadly, pogo pins are not what I'm looking for as only one end moves and they are make for electrical connections. I am looking for something where the spring loaded inner cylinder comes out of both ends so when I press on the top the bottom moves down
Logged
mjkuwp
Supporter
Country:
mechanical engineering defector
Reply #3 on:
June 02, 2017, 05:38:09 pm »
perhaps these terms:
spring plunger
index plunger
Check:
http://www.essentracomponents.com/en-us/tooling-positioning-components/locating-positioning-components/ball-spring-plungers-accessories/index-plungers
https://www.carrlane.com/en-us/
http://www.vlier.com/
mcmaster.com
Logged
ajb
Super Contributor
Country:
Reply #4 on:
June 02, 2017, 05:43:31 pm »
If all else fails, sounds like the sort of thing that could be made relatively easily from a piece of brass rod, brass tubing (or perhaps an externally threaded bushing), and a couple of shaft collars.
Logged
calexanian
Super Contributor
Country:
Reply #5 on:
June 04, 2017, 04:16:08 pm »
You want a solenoid. Or a solenoid mechanical actuator. Search with solenoid and it should get you closer to what you want.
Logged
Charles Alexanian
Alex-Tronix Control Systems
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
