For anyone who is also interested in this display, I found a video on youtube explaining it a bit:
It's a simple SRAM-like interface (without address lines). Should be pretty easy to port another library to your microcontroller? All you have to do is replace the very low level GPIO functions.
It can work with a 8-bit bus, but if you want any reasonable frame rate (ie, not just a static display), you'll probably need 16-bit bus attached to a microcontroller's external memory interface (eg. STM32F4 or F7).
Command 0xf0 configures the pixel data interface. If you set it to 8 bits you can use an 8 bit parallel bus with either 8080 or 6800 style timing. Commands only use D7:D0 and ignore the top 16 bits; only pixel data seems to use the additional width, if you configure it to. (Power-on default is to use the full 24 bits.)
This looks pretty neat actually, so I ordered one for use with MSP430 and ARM...
