Poll
Regarding surface-mount technology, in my lab
I only use through-hole component and cannot/don't want to use SMT
4 (2.8%)
I am thinking of using SMT but I need to improve my soldering
8 (5.6%)
I have the skills and tools to handle most packages (e.g. QFN, 0603) but populating a THT board is easier and more fun
16 (11.2%)
I have the skills and tools to handle most packages (e.g. QFN, 0603) and I actively try to use SMT as it is electrically better and looks cooler
72 (50.3%)
I can handle most large packages (e.g. SOIC, 0805) but populating a THT board is easier and more fun
8 (5.6%)
I can handle most packages (e.g. SOIC, 0805) and I'm working towards QFNs and BGAs
34 (23.8%)
Other/What is this SMT stuff anyway?
1 (0.7%)
Total Members Voted: 141
Voting closed: January 04, 2014, 03:37:38 am
Author Topic: State of SMT in the hobbyist's lab  (Read 16834 times)
Offline strangelovemd12
Re: State of SMT in the hobbyist's lab
« Reply #25 on: December 05, 2013, 11:24:40 pm »
I'm pretty new to hobby electronics and have yet to dive into SMTs much, but it seems to me that besides mastering the required soldering skills, the other disadvantage of using SMT for hobby work is the required use of PCBs.
For prototyping there's bread-boarding that requires TH of course - but also with so many options --  using perf, strip or proto board, dead bug or Manhattan style available to build with TH,  it doesn't make much sense for many (not all) one-off projects to go to the effort of PCB design and production. Does it?
There are some boards for SMT proto, IIRC user mikeselectricstuff sells some nice ones out of England.  There are also a ton of breakout boards for pretty much every package on eBay.  With a 90* header they actually make breadboarding incredibly easy and tidy.  If you plan on being in the hobby for long you're going to need to learn SMT anyway, or you wont be able to use any modern chips.  Just jump in.  The water's fine and the sharks only nibble.
Please hit my ignorance with a big stick.
Offline mtdoc
« Reply #26 on: December 05, 2013, 11:39:20 pm »
Thanks. Yeah - I've just recently started using a few breakout boards for use with SMT only chips.  I've seem the SMT prototyping  boards but haven't found the need.
 I've no doubt that eventually I'll dabble in building with SMT caps and resistors on PCBs.  I realize that for some projects there are real advantages.   The thing is, one of the reasons I enjoy hobby electronics is the physical hands-on work of building things.  The idea of spending more time in front of  a computer to do PCB  design does not appeal much to me.  I just recently watched Chris Gammels short youtube series on using KiCad for designing a simple Blinkly PCB board - doesn't look like much fun to me. I already spend way to much screen time for my day job - not to mention reading EEV blog... ::)
Offline ThomasDK
  • B.Eng. EE
« Reply #27 on: December 05, 2013, 11:54:30 pm »
I use surface mount as much as possible. I'd rather spend my time soldering and troubleshooting, than drilling all those pesky holes  >:D
If I need to run multiple traces under a resistor, I use standard PTH resistors, but I change the pads and surface mount them  O0
Offline free_electron
    • SiliconValleyGarage
« Reply #28 on: December 06, 2013, 12:25:38 am »
you need a few other options
- i handsolder 0201 without blinking...
- what the fuck are thru-hole parts ? something that predates the stone age ?
- the original integrated circuit package was intended for surface mounting (SN501 chip from TI) and introduced in the late 50's ... so why did we spend 50 years mucking about with something else .... it was always meant to be surface mount !
i'd have to select all the above options.
Offline Phaedrus
« Reply #29 on: December 06, 2013, 12:32:20 am »
Thru-hole can be useful on a crowded board; you can use your resistors as junctions to make routing easier. Sort of a niche application though. I only use thru-hole for quick bodgy perfboard prototypes.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline amyk
« Reply #30 on: December 06, 2013, 02:23:48 am »
How about some hand-soldered 01005. :)
Offline SLJ
    • Steve's Antique Technology
« Reply #31 on: December 06, 2013, 03:46:44 am »
I work on all three, pre circuit board equipment, through hole, and now SMD.  I just set up a second station just for microsoldering with new equipment.  It's a little hard doing SMD work with the old soldering guns and stations I use on the vintage gear.
Online Psi
« Reply #32 on: December 06, 2013, 04:15:13 am »
Offline chrisc
« Reply #33 on: December 06, 2013, 05:48:14 pm »
THT & SMT whats that. I use square copper onto which I wind silk thread and go point to point with nice right angle bends on a piece of ebony or slate. I find that its much easier to lift components with a gantry or fork truck. :-DD
That kind of reminds me of verowire. Cleaning out the garage a few months ago and came across a few vero projects I did back in the late 70's. I still have my vero kit stuffed in a drawer somewhere.
Anyone else out there remember using verowire?
« Reply #34 on: December 06, 2013, 06:47:10 pm »
Did not buy the system but have used enamelled copper wire to do wiring on a few boards, mostly for mods or to use small SMT components or to connect to existing small PCB's like watch boards.
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #35 on: December 06, 2013, 06:58:27 pm »
If I'm making a PCB in my home w/shop then it's 95% SMT, usually 0805/SOIC/SSOP.
Looks far nicer than THP, and you get that good feeling when you pull a board from the reflow oven......."tada!".
Downside with SMT is I'm nearly 50 and my close-up vision isn't as good as it was, i.e. I can't get my face right up against a board like I used to be able to when troubleshooting.......however, it's bearable and I'll use a magnifier if I have to.
Ian.
Website: www.ianjohnston.com
Offline nukie
« Reply #36 on: December 06, 2013, 10:35:22 pm »
SMT all the way, its less of everything, less solder, no lead trimming, less board space, less storage space, less weight. Thru hole for education purposes and bulk items that require secure attachment
Offline ampdoctor
« Reply #37 on: December 06, 2013, 11:08:01 pm »
I can deal with SMT but I'd rather not under most conditions. However, for prototypes and things I expect to fiddle with a lot I'll often gull wing or fully splay the leads on my through hole parts and leave larger E-lytics, relays, etc as through hole components. This seems to be the best of both worlds for me at least. Now I have far fewer holes to drill, I don't have to mess around with losing, reading, or even identifying microscopically small parts, storage of redundant components in different package sizes, dealing with reflow ovens, storage of solder paste or any number of other annoying elements. And if for whatever reason the chain of custody of something I built is ever broken, I can be pretty sure that whoever has it will be able to work on it or get it worked on easily.
Offline AlexTopic starter
« Reply #38 on: December 06, 2013, 11:25:36 pm »
Ian.
Good point - I wonder to what extent vision/handling makes SMT too difficult to work with for the broader 30-50 age group, to the point where it might affect a purchasing decision. Say for example you are looking for a guitar amplifier kit. Would SMT put you off? I see there is a tiny fraction that voted for I cannot/do not want to use SMT.
Offline briandorey
    • Project Blog
« Reply #39 on: December 06, 2013, 11:48:30 pm »
I started working with SMT components approx 18 months ago and now use them daily, mostly 0805, SOIC and TSOP packages. Most are placed by hand using a vac placement machine we built as placing with tweezers was proving too difficult!
The attached photo shows a new more compact version of the machine before we fitted a base to hold the PCBs
Offline Galaxyrise
« Reply #40 on: December 06, 2013, 11:51:17 pm »
After years of working with THP and wire-wrap, I finally got tired of not being able to fix anything modern.  My biggest problem at 58 is my eyesight, so I found a 7-40X binocular zoom microscope and that put me back in business.
Which did you get?
I am but an egg
Offline Po6ept
« Reply #41 on: December 06, 2013, 11:57:26 pm »
After years of working with THP and wire-wrap, I finally got tired of not being able to fix anything modern.  My biggest problem at 58 is my eyesight, so I found a 7-40X binocular zoom microscope and that let me tackle anything with exposed leads.
It's odd, but looking through the microscope I find that my hands are far less shaky than when looking through jeweler's glasses or a magnifying glass.  Something in the visual feedback and the apparent huge size of the parts and the iron tip makes the process much easier than I thought it would be.  I highly recommend a microscope, especially if you can set it up with a rack and pinion to adapt to different workpiece thicknesses.  I'd like to try a USB microscope and monitor but haven't found one yet that works.
Offline Po6ept
« Reply #42 on: December 07, 2013, 12:10:39 am »
Which did you get?
Sorry for any confusion in the posting, but I only just joined the forum and decided to start off using a different user name.
I found a used American Optical Stereo Star AO 570 0.7x to 4.2x on a stand that the previous owner made.  It has a miniature fluorescent ring light built onto it.  He did a really nice job putting it together - much nicer than I could have done with my metalworking skills.  My only complaint is that I have to remove the PCB from a radio before I can work on it.  I need to improve the stand and make the travel longer to accommodate the case thickness of the workpiece.
Offline MatCat
« Reply #43 on: December 07, 2013, 01:25:18 am »
I personally prefer SMD myself, I find it quite a bit easier to work with (Yes, easier then PTH), cheaper, and smaller overall end design.  Generally I do most of my design in 0805, but go to 0603 or even 0402 when I need too, all can easily be done by hand, though I do prefer solder paste for SMD instead of traditional solder, but either way is quite doable easily.  It takes me WAY longer to do a PTH DIP package then say a SOIC or TSSOP, if doing it by hand with an iron a quick bridge across the pins and a quick run with wick works amazingly well and fast.
Offline chrisc
« Reply #44 on: December 07, 2013, 03:56:14 am »
I'll venture a perhaps surprising opinion here.
As a result of an eye inflammation I had in my younger years, I had cataracts and consequently had both natural lenses replaced with artificial ones (aka interocular lenses). One thing about these lenses is that you completely lose the ability to focus as they are not flexible (like natural lenses are). This is basically the same thing that happens as you get older (the muscles in the eye get weaker and limit the ability to focus). In addition I am in my 50's already. So, I have the same sort of focus issues as someone who is quite a bit older.
Despite that, I have recently started doing some hand SMT assembly and find that I now prefer it to traditional board work for anything that has more than 20-30 components. Here's why:
I use a head-mounted magnifier most of the time and a loupe for close-up inspection. With SMT assembly I can have all the components in a set of little clip-cases (http://dx.com/p/4580) right next to the board and thus don't need to shift my attention very far away from the board (meaning typically I can keep the head-mounted lenses over my eyes). Also there's no handling of the board to flip it over etc. I can pretty easily handle 0402's this way; e.g. I built the board below by hand recently doing exactly this. [Yes it's a bit wobbly in places and needs a clean, but it works:]
With traditional parts a complex board will have components placed all around me and I'd be constantly having to switch glasses to look between the board and the shelves.
Putting it another way: once you lose the ability to focus, to shift your view from something close to something further away you need to either use bifocals or progressive lenses, or have several different sets of glasses with different focal lengths.
The issue with bifocal/progressive lenses is it forces you to look in a particular direction (or to tilt your head in an uncomfortable way) to focus on something that isn't where the lens would naturally look. I detest this as it leads to a sore neck or eyes.
The other way is then to have several sets of glasses, which is my solution. However if wearing the head-mounted magnifiers I can get away without glasses and when I flip the magnifier up I can see the clip-box well enough to be able to read the labels and extract the components I need without having to physically swap glasses.
Of course there is a down-side: it requires a steady hand and some preparation to do the assembly, but nevertheless I know from experience that assembling a larger, through-hole version of the board shown here by hand would definitely take me longer than it does for the SMT one.
Of course for others the situation may be different; this is just the point of view of one person.
Offline chrisc
« Reply #45 on: December 07, 2013, 04:02:38 am »
Even today I find the verowire is occasionally handy for little patches or board mods because it's fine enough to go through almost any via plus you don't need to strip it (the insulation evaporates when soldered). However you need to have proper ventilation when soldering it because of the gases released from said evaporation .
Offline andyturk
« Reply #46 on: December 07, 2013, 04:39:28 pm »
Other - yes I do BGA and even CSP. A microscope and good tweezers is essential, along with a hot air station, but other than that (and the occasional lost part) I think it's not too bad... then again, I've played with bare die so my sense of scale is probably quite distorted.
There are some chips I'd like to play with, but they have 0.4mm BGA/CSP footprints. How would you manage something like that in a home lab?
Is there a "cheap" way to have via-in-pad boards made in prototype quantities?
Offline M. András
  • Country: hu
« Reply #47 on: December 07, 2013, 05:04:35 pm »
ive ordered some boards from itead and seed, they didnt care about the numbers of vias i had enough in 5x5cm connecting planes and most of them was in smd pads dpak and nxp lfpak footprints with 0.5mmholes, they state mininum drill size is 0.3mm it maybe still doable but i would sware the amount of solder on the ball would be enough cos of the via
