Author Topic: Status indicator that doesn't use power?  (Read 32348 times)
Online ataradov
    • Personal site
Re: Status indicator that doesn't use power?
« Reply #25 on: April 06, 2022, 04:52:47 pm »
AndyC_772 suggested it in a post #10.
There seem to be no LCDs like this (single big segment) on the market, so it would have to be custom made.
Alex
Offline brichards42Topic starter
« Reply #26 on: April 07, 2022, 12:35:10 am »
Why isn't anyone suggesting a very small lcd display with a few segments? Make it transflexive and you don't even need backlight... and you'd probably only need to pulse it once every few seconds to keep the liquid cristal working.
I think a small lcd display would be good choice if you are using a mcu with enough pins to drive it and it doesn't need to be noticeable at any distance.
Offline DavidKo
  • Country: cz
« Reply #27 on: April 07, 2022, 09:25:48 am »
What about using the LCD (maybe even dot matrix), but to hide for example red sticker behind it. When you turn off the power supply, than it will not be hiding the thing behind it. Also you can use 7seg LCD with reversed polarizer (numbers will be transparent for the active segments with black surrounding) and turn on the 1 and have green background. Such a approach will work even without battery, but will have higher power consumption with good battery.
Other thing what I have met, is used in smoke detector (Hütermann F9), which beeps once every 43s, when the battery is low.
Offline DavidAlfa
« Reply #28 on: April 07, 2022, 09:37:21 am »
There're single-pixel lcds for soldering equipment:
www.aliexpress.com/item/1005002280725964.html
However the polarity might be reversed to what you need.
Offline Psi
« Reply #29 on: April 07, 2022, 11:57:14 am »
Maybe one of these ~$2 linear actuators with the arm connected to something that shows the low battery message. OR maybe even use it like a battery gauge display with one side 0 and the other 100%
https://www.aliexpress.com/item/1005001421552415.html
https://www.aliexpress.com/item/1005003719349382.html
« Last Edit: April 07, 2022, 12:15:10 pm by Psi »
Offline DavidAlfa
« Reply #30 on: April 07, 2022, 12:39:08 pm »
The problem with servos and actuators is that the indicador will keep showing "ON" if the power is suddenly removed.
Offline Terry Bites
« Reply #31 on: April 07, 2022, 04:39:53 pm »
Us Europeans are worried radiation trefoils may become be a common sight!
Actually, I think these flag things were used on trains
Offline SilverSolder
« Reply #32 on: April 07, 2022, 04:52:17 pm »
That's amazing. I didn't know anything would be visible at that level. My previous thought was that a low batt indicator is a dumb idea. I once had an answering machine that flipped on an LED to warn of low batteries. That quickly drained them, causing them to leak and destroy the device. Brilliant design or stupid design, I'm not sure. As for "any" modern LED, I'd suggest testing it first, and making sure most of the batch was useful at that level if this is a production device.
I prefer the inverse of that:   Indicate that the battery is good! -  if the "good" indication is not there, you know it's "bad"....    and that uses no power!
