Benta is correct in saying that the "copper fill factor"has influence, but that is something you have no controll of, unless you wind your own stepper motors.
The Voltage and current ratings on stepper motors are for DC, and For low speed applications there is little difference.
If you have for example an Nema 23 motor with a 5V 3A DC rating, it is quite common to use these with a stepper motor driver and a 24V or even 48V power supply.
The overal goal of the stepper motor driver is to generate 2 Sine wave currents with a 90 degree phase difference (for a 2-phase motor). For this it puts the supply voltage on a stepper motor winding untill the target current is reached, and from there it modulates the current and uses the motor inductance as part of a SMPS current regulated circuit.
At higher RPM of a stepper motor it becomes difficult to push enough current fast enough through the stepper motor winding.
Increasing the power supply voltage helps to achieve higher RPM, (or to maintain torque at high RPM).
With lower self inductance of the windings, it also becomes easier to push more current through a stepper motor winding, which also results in higher achievable RPM before the torque drops to a low value, or in extreme cases the motor simply stalls.
Fetch some random datasheets of stepper motors. Most have a graph which plots available torque versus RPM and they often plot curves for different supply voltages in the same graph.
Some of the motors have each winding separated into 2 physical coils, which can either be put in series, or parallel.
When the windings are parallel, each winding has the same (maximum) current, so the total current will be doubled, but the indutance is only 1/4 compared to windings in series.
If you find a datasheet of such a motor it will have the above mentioned graphs for both configurations.
Putting the windings in series has some advantages for low speed applications. Losses in the stepper motor drivers increase with motor current, so this configuration will have a bit better efficiency with low RPM.
A problem with some stepper motor drivers is that they need a minimum motor inductance to work properly.
In the last few years the "closed loop" stepper motors are becoming more popular. (Nema23 and bigger).
These have a quadrature encoder which measures motor position, and normally regulate the motor current to a (much) lower value than the maximum. This results in higher efficiency and in much quiter and smoother operation of the motor.
I've collected some links to open source projects which make use of this principle:
https://hackaday.com/2016/06/01/mechaduino-closed-loop-stepper-servos-for-everyone/https://hackaday.io/project/20980-ananasstepper-20https://www.crowdsupply.com/citrus-cnc/taroccohttps://trmm.net/ServoStep#Testinghttps://github.com/neuroprod/ClosedLoopDriver
