But who makes it? I can't seem to find a datasheet or dimension for it either.
Do not know, I have not bought any. They tend not to have data sheets for anything other than silicone devices.
Try emailing them (or even phone them if you can find a number).
Bitsbox seem to be a small company so should be willing to help.
Thanks, I might give that a try. But if it is the same as what I'm sourcing, I'm still very interested in finding the source brand and part number.
Another option would be something like VCC CLB300CTP. It's a snap-in lens that's installed from the front of the panel and then the LED is inserted from the rear, so it can't be pushed in, and it's low profile so it would be hard to pull out from the front. The LED helps lock the lens into the panel, and you can get retaining rings to suit different panel thicknesses.
I hadn't considered that. I have a few left over from a previous project that I'll try out.
VCC is leaving me quite sour - 2 emails and no response yet.
I did get in contact with someone at CML, the company that sold the component prior to selling/spinning the division to VCC, and they said it was designed to work with their LEDs that have a certain flange so as to not deform the holder when inserted. That series of LEDs wasn't in stock at any of the places I ordered from, so I went with other VCC LEDs and some other brands'. The VCC LEDs have the same dimensions, but deform the holder. It's bizarre.
I managed to get 2 assemblies successfully connected out-of-panel using 2 sockets, so my next step is to use a nut driver or sockets for a panel install.
Those metal holders won't prohibit the LED pushed inside. The only fixture is the black plastic part pushed in. If you like I can make a picture or two of this type showing how it works. Either you use glue or something else. If you're now looking for the type with the lens/IP rating: The lens can be unscrewed from the front...
I think that's not the manufacturer from your specific version. But http://www.signal-construct.de seems to build similar holders. Look in this part: http://www.signal-construct.de/images/stories/pdf/fpi/8mm%20Metallgehaeuse.pdf. They have a nice big selection. Maybe you'll find what you need.
Edith: Added link to catalogue.
I know. My interest in those is for another project. I figured that since I was already talking about LED holders, it was worth tacking that question onto the same post, rather than posting twice.
The Radio Shack/Tandy version has a soft rubber plug. Most of the others I've tried since trying to find the OEM have hard plastic plugs.
The reflectors are deep enough that it should be hard to push out an LED, but a drop of hot glue around the plug might help. Or cutting down the plug depth and placing a drop of hot glue within the socket.
And one more thing as you requested to use your own LEDs: At least some of the Signal-Construct mounts are available without LED. Reichelt here in Germany has them without LEDs but they might got a special deal.
Thanks, I'll check them out further!
In my opinion, the metal LED holders are not suitable for use in a toy made for a toddler. They have a portion of the metal that protrudes out from the LED, And If the toddlers should fall against these protrusions, It could seriously injure the toddler. They also tend to's swing and throw things. You would be better off to mount the LEDs on a circuit board, and secure the circuit board to the panel. When it comes to making anything for a child, you need to consider their age, and safety relative to that age.
Joe.
Very good advice, thank you. Please be reassured that I asked about the metal holders as a separate inquiry, intending for their use to be in a benchtop project of mine, and in future projects.
For projects that will be accessible by my son, there are to be no sharp edges or potentially hazardous protrusions. And any assembly will only be in his reach when under direct supervision.
