Author Topic: Subharmonic oscillations in DC/DC Converters  (Read 4185 times)
Offline treeTopic starter
« on: August 04, 2014, 02:56:47 pm »
On page 72 of http://cds.linear.com/docs/en/application-note/an19fc.pdf, it's stated that subharmonic oscillations occur for a duty cycle greater than 50%. Why don't they occur for a duty cycle less than 50%?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Subharmonic oscillations in DC/DC Converters
« Reply #1 on: August 04, 2014, 06:03:20 pm »
A convenient approximation (and design choice), I think.  What matters for a peak current mode controller is if there is residual current in the inductor; if the system is designed so the flyback (or recoil or whatever) voltage equals the supply (so the switch switches Vs*2, and etc.), then current becomes continuous at >= 50% duty.
As for the oscillations themselves, the fundamental downside to a peak current mode converter (even with slope compensation and an error amplifier) is it exhibits chaos; duty cycle acts like the feedback parameter in the logistic map, and an identical bifurcation diagram can be generated from the circuit.
Seven Transistor Labs, LLC
« Reply #2 on: August 04, 2014, 11:23:27 pm »
You just enjoy confusing me to death!
Offline David Hess
  • DavidH
« Reply #3 on: August 05, 2014, 12:54:16 am »
I thought the application note described it pretty well.  Reread the part at the beginning about S1 and S2.
« Reply #4 on: August 05, 2014, 01:03:05 am »
I finally figured it out. The change in duty cycle corresponds to a decrease in time for the positive slope and an increase in time, of the same amound, spent for the negative slope. The equality I1/S1 = -I2/S2, where I1 and I2 are the deltaI for the positive and negative slope, respectively. The equality is saying the exact same thing that I described in words. I2 = -S2/S1 * I1. The current perturbation will continuously increase if S2/S1 is larger than one, i.e. DC > 50%
Offline T3sl4co1l
« Reply #5 on: August 05, 2014, 02:31:27 am »
Yup, and for higher duty cycles, it bumps into a 4-cycle, then a slight bit more into 8, and so on...  Hence, bifurcation: http://en.wikipedia.org/wiki/Logistic_map
The bifurcation diagram shows the discrete points (for the map, the numerical values; for the converter, the pulse widths) that are cycled through, on the Y axis, with (average?) duty being the X axis.  It looks strange and beautiful, and doesn't make much sense at first (you can't plot it on an oscilloscope).
Offline David Hess
  • DavidH
« Reply #6 on: August 05, 2014, 03:14:25 am »
Come to think of it not only does my DSO support roll mode but also a "scan" mode where the display record is updated in real time at slow timebases and a cursor shows the current scan position.
