I am looking for a PCB mountable 3 axis tilt sensor with low drift. It should have <0.1° accuracy after 5 years. I can calibrate it once, but then it is in the field without access. Temperature range -20°C to 60°C, but only with slow changes. No harsh shock or vibrations.
The best candidate I found is the ADXL355 with the special ceramic case, but it is a bit expensive for relatively high volume.
Are there a bit cheaper (half the price would be great) options where you don't have to pay the analog price?
