Author Topic: suggestions for high-resolution tiltmeter (inclinometer) sensor?  (Read 53715 times)
Offline rhb
Re: suggestions for high-resolution tiltmeter (inclinometer) sensor?
« Reply #100 on: June 04, 2018, 09:28:51 pm »
Here are photos of the mount in my Chinese machinist's level
Offline rhb
« Reply #101 on: June 04, 2018, 09:29:26 pm »
one more
Offline metrologist
« Reply #102 on: June 04, 2018, 09:58:35 pm »
Cool, I wondered what was in there. If I understand its operation, the right side is a pivot (with pinch screws to position in center and probably take up some pivot slop) that is jacked by the screw on the left.
I figure I can make an old piece of "lead" pipe work for a carrier if I do not find a chunk of cast iron. Some name brand appears to use aluminum tubing, or perhaps it is stainless?
Offline rhb
« Reply #103 on: June 04, 2018, 10:23:39 pm »
The vial is sitting in the metal tube with a thin clear plastic ring around it.  There's  access to the adjustment screw through the top cover. The pointed screws are behind the insulating side handles.   The points are probably the actual pivots and the pin is just so they can be set.  If you think about the tolerances (this is a 10"/2mm vial) the slop of a pin in a hole would make it unworkable. 10" over the ~5" vial is 0.00025"
I'd suggest using a pair of good grade O rings to hold the vial in a metal tube.  Set the adjustment screw in minimum position, tighten the pivot screws so they *just* dimple the metal and then adjust for level.  Use a pin which is 3-5 thou smaller than the hole to allow free movement over the adjustment range without straining the tube.  It's really just there as an aid for setting up the vial so it can be adjusted.
Offline JBealeTopic starter
« Reply #104 on: June 04, 2018, 10:55:45 pm »
Thanks for those photos! I was just thinking about how to do the leveling adjustment. I assumed I would need some compound lever to reduce the motion, since even a 80 TPI micrometer leadscrew would be awfully fiddly lifting a 10 cm long lever arm, if you are resolving at the arc-second level.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #105 on: June 04, 2018, 11:15:24 pm »
I think many levels and old transits used plaster of Paris to bed in the vials.
Too fussy for most, but if you have the machining capability, you can make a differential screw for adjustment.
Offline rhb
« Reply #106 on: June 04, 2018, 11:24:31 pm »
I was expecting to see plaster of paris when I opened it up.  Long term that's probably more stable.  Thanks for bringing that up.  I got somewhat distracted by the pointed screws which I did not expect to see and which took some thinking to figure out.
Edit:  For a capacitance sensed vial plaster of paris around the electrodes would cause problems, but O rings would let one pour plaster into the ends without it running down to the electrodes.
BTW I haven't used it in quite a while, so I don't recall how fiddly it is to adjust.  I habitually test levels by reversal every time I use them.   I remember I did it, but that is all.  It's certain to be "breathe on the screwdriver" and it moved too far.
I'm quite eager to get some  4"/2mm vials and duplicate your work.
« Last Edit: June 04, 2018, 11:41:28 pm by rhb »
Offline rhb
« Reply #107 on: June 04, 2018, 11:42:47 pm »
I've never heard of a differential screw.  Please explain.
Offline metrologist
« Reply #108 on: June 05, 2018, 12:08:31 am »
Indeed...photos are awesome and appreciated! These are usually over 100+ cm. I think my pivot will be 5"
I think on the order of 20 degree turn of the leveling screw would be one full division (for 4" graduated vials, 80 tpi).
Yes! now you temp me with complexity and elegance.
Offline ez24
  • L.D.A.
« Reply #109 on: June 05, 2018, 12:14:49 am »
FYI - Received my two vials which are too sensitive for me (I forgot my trig).  Also got two less sensitive vials.  Pretty fast shipping.
« Reply #110 on: June 05, 2018, 12:17:32 am »
Use your Google-foo and do an image search on differential screw. Lots of images that are better than any description I can give. Basically it subtracts the motion of two very closely chosen thread pitches. The difference can be stupidly small, in fact errors in machining can be larger than the motion of the screw, so don't make it too fine.
Offline ez24
  • L.D.A.
« Reply #111 on: June 05, 2018, 12:40:04 am »
.. differential screw ..
Interesting   :-+
Offline rhb
« Reply #112 on: June 05, 2018, 01:21:46 am »
Piece of cake, Trip to hardware store,  a hacksaw cut and some epoxy or silver solder.  The only hard part is aligning it  and finding left hand threads.
I'm surprised I hadn't encountered the idea before.
« Reply #113 on: June 05, 2018, 01:07:35 pm »
Depending on how you do it, you don't even need a left handed screw. In the image above, the whole screw moves forward through both nuts. It's only the slight difference in pitch that causes the movable nut to move. The more compact way to do it is with concentric parts, and you turn the central "nut" that's both internal and external threaded, to move one of the screws. I think Lansing sold a diff mic that was actually made for them by Starrett. Burleigh sold one for a while that was made by Slocomb. Newport sells one, and Thor Labs too! None are cheap.
Offline branadic
  • Sounds like noise
« Reply #114 on: June 05, 2018, 05:26:17 pm »
I spent 5 mins on google and could not find the spec.
I've contacted W. A. Moyer & Sons and hopefully they are communicative enough to give some specification on Level Vial Type L1 A31314. My experience with companies beyond the great lake is not that positive when asking for informations about their products.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline StillTrying
  • Country: Broken Britain
« Reply #115 on: June 05, 2018, 06:55:12 pm »
After being stuck with 75 year old stock for years, the ebay seller must be wondering why his L1A31314's are now selling like hot cakes. :)
« Last Edit: June 05, 2018, 07:08:13 pm by StillTrying »
Offline metrologist
« Reply #116 on: June 05, 2018, 07:52:44 pm »
Lol, has the price gone up yet?
Now I'm wondering how I will thread a fancy differential screw into that chuck of scrap iron I have? I was considering an 88/92 TPI combo.
« Reply #117 on: June 05, 2018, 08:50:52 pm »
Seems like any kind of threaded mechanism will be expensive and take up some space.  Assuming it can be set once and for all, there's something to be said for the time-honored simplicity of plaster of paris. Dirt cheap and compact. One-time only, but has unlimited adjustment range and you can make progressively finer adjustments to the vial as the paste gradually stiffens during the set.
« Reply #118 on: June 05, 2018, 08:55:21 pm »
Yikes! That would be the equivalent of a 2024 tpi screw! 1/88 - 1/92 = 0.00049 per turn. Geometry errors will probably cause it to move back and forth more for each turn, than it moves forward or reverse, unless you're really good at making the parts.
Offline branadic
  • Sounds like noise
« Reply #119 on: June 05, 2018, 09:10:35 pm »
After searching a while in the web I'm now sure that sensitivity of the vial is in the order of 20"/2mm. There are similar vials available on ebay that can be used for this purpose. There are also vial with 3"/2mm available.
-branadic-
Offline metrologist
« Reply #120 on: June 05, 2018, 09:51:19 pm »
Yes, and at 5" pivot, would give me 6 divisions per turn. It sounds easy as I would single-point them on 1/4" drill rod.
Any suggestions on where to start looking? I think easy would be an 8-36 / 8-32 screw. I think I have both of those taps. That gives me 1 division for every 10° screw rotation.
Offline metrologist
« Reply #121 on: June 05, 2018, 09:58:28 pm »
Yeah? I cannot see that working. I'd watch it for hours and hope it cured enough, and overnight it will take a set and sag. I expect it would happen, not tried it.
Offline ez24
  • L.D.A.
« Reply #122 on: June 06, 2018, 12:21:16 am »
I was about to buy this:
https://www.aliexpress.com/item/-/32857223430.html?spm=a2g0s.13010208.99999999.261.7ed13c00BqqI0W
then I doubled checked my math and at 12 feet  1 degree is 2.5 inches not .2 inches (unit error) that I first thought.   This time I think I will go back to vials but 4" is much too sensitive but I like the 100mm length.
Can someone check my math  -  at 12 feet  4"  is .003 inches  (    tan(4/3600) x 144 = .003  inches  )
.003 is too little for me and 2.5 is too much.   So I will continue to look but the plaster idea sure solves the mounting problem.  I think 1 inch max is the most I could tolerate then I would have to re-level the building which is a full days job.
How to calibrate a glass vial and document the results?  In my case (not 4")  I was thinking of measuring the heights at the end of a 12 foot board for each division and make good notes in a notebook that will be attached to the wall inside the building.
Found this one  5'/2 mm x 100mm ->
https://www.aliexpress.com/item/High-Quality-Level-Vial-Bubble-Glass-Tube-Spirit-Level-Measurement-Instrument-5-2-mm-14-100MM/32879077293.html
Can someone check my math again (sorry but I am learning) :
At 12 feet  5'  means the difference between marks is 0.2 inches ?
If so I will mount 2 of these at right angles in plaster of paris.   My next question is how deep should I ?  I am thinking about 1/3 diameter?  I would like to be able to remove them just in case I screw something up.
Also found this on how to calibrate a glass vial:
https://www.leveldevelopments.com/wp/wp-content/uploads/documents/Engineers-Level-Calibration-Instructions.pdf
Offline StillTrying
« Reply #123 on: June 06, 2018, 01:39:24 am »
I thought you'd have found that 0.2inch -> 2.5inch error long ago!
Making a giant 24ft circle, and then dividing down the circumference,  both these are correct.
"at 12 feet  4"  is .003 inches  (    tan(4/3600) x 144 = .003  inches  )"
12ft x 12inch * 2pi / 360 / 3600 * 4" = 0.00279 inch.
"At 12 feet  5'  means the difference between marks is 0.2 inches"
12 * 12 * 2pi  / 360 / 60 * 5 = 0.209 inch.
I wouldn't have much clue on how to calibrate, I'd guess you'd move an amount of 10 or 20 divisions and then interpolate for the smaller divisions.
« Last Edit: June 06, 2018, 03:34:15 pm by StillTrying »
The following users thanked this post: ez24
Offline rhb
« Reply #124 on: June 06, 2018, 02:19:05 am »
1/4" in 12' is 6 minutes of arc. (atan( 0.25/144))
Fluid (water or mineral oil)  levels are far more appropriate for building movements.  The problem with a level vial is the length over which the angle applies is hard to determine.  It's not the length of the vial, it's the length and straightness of what it's attached to.
A fluid level at each foundation pier  is unambiguous.
