I'm not familiar with your 9080, but maybe I can generalize. I know there are two basic kinds of sync, one that gives a pulse for every wave, and one for sweep mode that gives the start (and end) of the sweep, covering many waves during that time.
If I use the latter, and feed it into the trigger circuit of my scope somehow, I want the scope sweep time to be about two seconds if the generator sweep time is about two seconds.
At such a low rate, the scope will want a rather long trigger reset time, so there may be a noticeable gap between displayed sweeps.
The other thing I might do is go the other direction. My generator can take a trigger input to start a sweep, and so can my scope. So if I can create a trigger in some other way, I can trigger both my generator's sweep and the scope's sweep with that same signal.
