I am trying to design a 12V smart USB charger based around the TPS54394 step-down switcher from TI and I have run into a problem. I based the switching circuit off of a design from TI using their power supply workbench tool and it is supposed to work between 9V and 16V input. Up to 12V it works fine with a stable 5V output but above 12V the power output starts to get erratic with glitches like the ones in the screen shot I have attached from my scope. The higher the voltage gets the worse the output becomes. It also increases as the load on the output increases, with no load the output is smooth.
The circuit also includes a 3V supply using the other half of the TPS54394 and this side of the supply is working properly but that could be due to the fact that it is only powering a microcontroller and bluetooth module so the current draw is only a few milliamps and possibly not enough to cause the erratic behaviour that the 5V side is showing.
I don't have much experience with designing switching supplies, I normally use off the shelf modules so I am not sure if it is a problem with the circuit or the PCB layout. I have attached the schematic for the power supply part of the circuit as well as the PCB layout. Hopefully someone with a bit more experience in switching PSU design can tell me where I have gone wrong.
