I am designing a 2A constant current source for an electrolysis bath. Because of limited space and no cooling available, I need to use a switching regulator. So I came up with the attached schematic.
The most important characteristic is that the current through the plates has to be very clean DC. Especially free from any switching noise from the regulator.
UPDATEI have changed the schematic to the attached one. It is now using a synchronous FET SMPS with a resistance of 75mR. That should keep the SMPS IC relatively cool. But just to be sure, how do I calculate the temperature of that SMPS from the FET resistance, current and frequency?
Thank you
ORIGINALThe most important characteristic is that the current through the plates has to be very clean DC, free from any switching noise from the regulator.
I have chosen the inductor relatively large at 100uH and was also wondering whether to add a second low-pass LC filter after C1. I guess it can clean up the voltage further but would slow the regulator response?
An alternative I also thought of, is to do add the LC as just mentioned but then insert a current sense resistor but between C1 and the LC filter to implement a high-side current sensing for regulator's feedback pin. Would this be a better idea? And if so would it allow me to decrease the inductor value so to use a smaller one?
Thank you
