EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Tactile Switch Rating
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tactile Switch Rating (Read 1915 times)
rstor22
Regular Contributor
Country:
on:
April 11, 2015, 05:01:48 pm »
Regarding the following circuit:
http://electronicdesign.com/power/almost-ideal-low-battery-cutoff-circuit-draws-only-12-mua
http://electronicdesign.com/site-files/electronicdesign.com/files/archive/electronicdesign.com/files/29/4423/figure_01.gif
If I have a 1-2AMP load at the switched output, would the following tactile switch for S1 and S2 be adequate?:
http://www.digikey.ca/product-search/en?KeyWords=b3f-1000&WT.z_header=search_go
Contact Rating @ Voltage 0.05A @ 24VDC
I am unsure if I need a higher rated switch (i.e. 2A) as to my understanding once S1 is depressed the relay would be activated....
Or do I need a switch rated for 2A for this circuit (based on the 1-2A draw at the switched output)?
Last Edit: April 11, 2015, 05:03:51 pm by rstor22
Logged
zapta
Super Contributor
Country:
Re: Tactile Switch Rating
Reply #1 on:
April 11, 2015, 05:28:35 pm »
For a short time the switch will get the full rush current of the load. You can try decouple the power to the electronic circuit with a diode and then have the on switch powering only the electronics without carrying the load's current.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
