Author Topic: TCA0372 audio?  (Read 2585 times)
Offline heinrich.hugsTopic starter
TCA0372 audio?
« on: November 25, 2016, 01:33:16 pm »
This is my first post and the reason I signed up  :P so I primarily build guitar based audio electronics, and I love using loads of different op amps but its always annoyed me that I have to use a transistor based buffer for actually putting a voltage across speakers. So when I saw that this chip was rated for an amp I was quite surprised, is there any obvious downside for using this in audio applications?
Datasheet: http://www.onsemi.com/pub_link/Collateral/TCA0372-D.PDF
Online Zero999
  • 0999
Re: TCA0372 audio?
« Reply #1 on: November 25, 2016, 01:50:55 pm »
The slew rate will be too low to faithfully reproduce treble. It's also quite noisy compared to other op-amps such as the NE5532.
http://www.ti.com/lit/ds/symlink/ne5532.pdf
Why not use a dedicated audio amplifier IC? What are your load, power supply and power output requirements?
« Last Edit: November 25, 2016, 04:03:12 pm by Hero999 »
Re: TCA0372 audio?
« Reply #2 on: November 25, 2016, 02:07:40 pm »
Oh right thanks, never knew what slew rate meant... I mainly wanted to make a really clean no eq amp for me to put pedals through so maybe like 10W output over 16ohm speaker and a good bass response. I tried a amplifier chip can't remember what it was called but it required a capacitor over two pins that seemed to select the most amplified frequency?? I'm not sure.
Offline karoru
Re: TCA0372 audio?
« Reply #3 on: November 25, 2016, 04:02:24 pm »
The most popular power amplifier IC for audio is LM3886, maybe it was that one?
Re: TCA0372 audio?
« Reply #4 on: November 25, 2016, 06:33:46 pm »
No it wasn't that but that looks quite good I might try that instead thanks :)
Online Zero999
  • 0999
Re: TCA0372 audio?
« Reply #5 on: November 25, 2016, 07:05:30 pm »
If it's small and low power, it might have been the LM386.
