An interesting project !! You are a wise, very warm-hearted man!
How accurate is the resistance measurement? See all the pictures most of them are capacitors, almost no resistance! The 4-wire method is particularly suitable for low resistance, such as 0.001~0.5 ohm.
If you reduce the sampling frequency a little, can the Cs4272 use RP2040 or ESp32 as a driver? If you'd like to guide, I'd like to try it 。 Usually, the entry-level professional meter is only 100HZ、120HZ、200HZ、400HZ、800HZ、1KH、2KH、4KH、8KH and 10KHZ sampling rate. But it's accurate enough to do it very well. I have an entry-level LCR Meter in my hand,its maximum sampling rate is only 10KHZ, and even compared it with a 6 and a half bit multimeter,0.001~0.5 ohm, the accuracy is not lost. The 4-wire has a strong advantage.
This 4-wire resistance is very cheap, has a variety of resistance values, the accuracy is good, does not require 6 and a half bit multimeter or other expensive standard components. That's good enough for a reference, especially when it comes to used parts, which are cheaper. There's nothing under the case, it's just a resistor, and 4-wire mode is the best package.I send picture in the attachment .
An Very interesting project !!Happy life!! [/img]
