I've read that we are losing the knowledge of transformer design because all the knowledge is just in the heads of the guys who developed solutions like this. And as they retire and leave the workforce, their knowledge goes with them. And given the magic involved, I can begin to appreciate how that could be true.
Easy low voltage to high voltage- piezoelectric transformers!
Yeah, Jim Williams did an app note with one, but when I searched they were hard to find, wish they were more readily available.
What a beautifully simple way to balance flux, the effective voltages cancel one another if the flux is the same, and any flux imbalance gets compensated by the current flow, subtracting from one side and adding to the other, it wouldn't be perfect but good enough.
what if we try this balancer concept and put it on wide band transformers, like audio hifi transformers,they are used for signal isolation, but also very much in tube amplifiers, signal and power size, so it should be easy to add this windingand measure how it performs before vs after..plenty of active tube amplifier tech people out here who love cool ideas to try out ?
