I need a cheap small 2.4GHz Counter.
So I ordered a PLJ-0802, its perfect... I even can set IF Offset +- 1GHz....
Except, it can only measure up to 1.1GHz.
It has the MB501 Prescaler, so I thought I can replace it, with the Pin compatible MB506 Prescaler, which goes up to 2.4GHz.
It even has "MB506" Imprinted on PCB.
The MB501 is configured to 1/64, the MB506 Datasheet says it can be configured to 1/64 too. But it seems, it can only scale to 1/128 or 1/256.
Is it maybe possible to Hack the firmware, to accept 1/128?
